Question about Hobart Food Mixers
How to change the alligator shaft of a hobart m802 dough mixer 60qt
Need help taking it apart
A-200 hobart mixer grease leak, there is grease present in some of the doughs that we make, black streaks but there is nothing dripping on to the dough...
several reasons
too much grease worn bearings or bushes not holding the shaft in the center
worn out grease seal;
the fix is an overhaul and seal replacement
Nov 01, 2017 | Hobart Food Mixers
A Hobart A200 stand mixer that I cannot get the dough hook off of?
Try and get some CRC into the top where the hook joins the shaft. You need to be rocking it back & forth to try and get movement. Gradually the movement will increase if your strong men are strong enough and have stamina as well. Once you get it off clean up the shaft with a wire brush. Clean out the hole in the dough hook with the proper size drill, you don't want to make the hole bigger, just cleaner. It will be a build up of flour in there, it packs hard and shrinks the hole, almost unbelievable but true.
Aug 04, 2015 | Hobart A200 Stand Mixer
Why bowel not lifting after i put together
This is a kitchen device (mixer). I suggest you stop trying to use it as a medical device.
Jun 01, 2014 | Hobart M802 80 qt. 3 HP Dough Mixer
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
90quartmixer gears dont have power belt torn
Is the model an M802?Did the belt break or slipping?I'm a hobart tech,let me know.
Mar 03, 2009 | Hobart H600 Stand Mixer
Looking for location of drain plug for m802
Look behind where the dough hook is near the pedestal,its a three quarter inch bolt.
Feb 21, 2009 | Hobart Food Mixers
Need to Raise the stop height of the bowl on the H600
I should have know this was a scam to sell something.
Thanks, but no thanks.....
Dec 09, 2008 | Hobart HL600 Legacy Stand Mixer
Old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
Nov 29, 2008 | Hobart A200 Stand Mixer
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
Food Mixers Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
