Question about Craftsman 11650 6 Amp 10,000 Rpm Corded 4 Angle Grinder 900.11650
How to change brushes craftsman 900.11650
How do I get to them to change?
Where do you get motor brushes for a craftsman 4 6 amp angle grinder model 900.11650? Sears says they are unavalible.
probably correct from sears
but as sears do not make brushes you can try an appliance shop for generic brushes to suit your unit
brushes can be filed to width and thickness and fitted correctly by an experienced repair person so ask around
Nov 10, 2016 | Craftsman Saws
My circular saw is not working
Check brushes...
Dewalt Craftsman 2 Pack Carbon Brush Holder for Saws 147097 09 2pk
or sometimes the switch fails...
Craftsman 7621301 Circular Saw Switch
if you luck out, it may just be a broken wire, right at the switch, or right where it enters the saw? Pulling the, or directly on the cord vs. just the plug puts a lot of strain on the wires.
But if it is one of the parts above, very easy repair.
Apr 13, 2015 | Craftsman 7 1/4" 12 Amp Skill Saw
I have a Craftsman 125 psi 1.5 hp 3 gallon air compressor. When I plug it in and turn on I see a blue arc come from somewhere. How do I fix this?
If the blue arc is coming from the motor it might be an older motor that uses brushes. If the motor is serviceable you would need to take apart the motor and change the brushes. Blue arcs don't usually come from shorts
Mar 01, 2015 | Craftsman Air Tools & Compressors
How do i service or change brushes in my 1955 craftsman oiless sprayer
Contact Craftsman unless it is now too old and if so check with a small appliance/tool repair shop in your area
Oct 15, 2014 | Air Tools & Compressors
Where can i buy carbon brushes for my craftsman leaf blower 358 799 400
Parts for Craftsman equipment can be obtained at you local Sears store.
Jul 30, 2014 | Dewalt Dw4902 1-inch By 1/4-inch High...
Need brushes for an older craftsman scrolling jig saw
If sears does not have them many hardware stores have a selection of brushes that may fit.
Jul 21, 2011 | Craftsman Saws
How to change the brushes in the older Craftsman tool. Seems they are placed in the motor and the end closed by small tabs bent down?
if that is the case without having the model number it sounds like they are not replaceable and you would have to buy a motor assembly. Alot of tool mfrs did not make these brushes replaceable.
Jun 26, 2011 | Craftsman 14.4 volt Cordless Drill/Driver...
Have a MODEL 572.610530 CRAFTSMAN ROTARY TOOL. TURNED ON UNIT AND BEFORE I STARTED USING IT, THE TOOL SHUT DOWN. I EVEN CHANGED OUTLETS TO MAKE SURE IT WASN'T THE OUTLET...IS THERE A WAY TO RESET TO...
Hi and welcome to FixYa, I am Kelly. First off you did not mention the age of this tool which would have been quite helpful in my response.
I looked up your parts here:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Rotary-tool-Parts/Model-572610530/0247/0741520/10043672/00001?blt=06&prst=0&shdMod=572610530
You should inspect the brushes (item 11) for wear or broken springs. From what I can tell this particular model has been in the retail market place for at least 10 years. This would lead me to believe that the brushes are suspect. The brushes can be removed by unscrewing the opposing "screwdriver slotted" plastic caps on the outside of the tool and then carefully lift them out for inspection.
Use a flashlight and inspect the armature where the brushes come into contact. It should be shiny copper colored and not dark or black.
I also note that the switch has 5 speeds. Since it does not work on any speed... I doubt the switch has failed.
Detailed view:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f10043672-00001.png
Your manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709185.pdf
If you have more questions after inspecting the brushes, feel free to respond anytime with those questions
Thanks for choosing FixYa,
Kelly
May 18, 2011 | Craftsman Tools & Hardware - Others
No control of speed on bench grinder,need schematic
Unless the motor is a brush type universal unit, there is commonly no way to change the speed of an induction motor. There are AC motor speed control units available, but cost more than the grinder as they change the frequency as well as the voltage. There are speed controllable grinders available that use brushes so that simple electronics can control speed. Hope this helps!
Dec 08, 2010 | Craftsman 6" Bench Grinder with Lamp
Need brushes for the motor in my Craftsman Vac
Hello. The best source for all craftsman parts is sears.com regards, Joe
PS - kindly rate my answer helpful. thanks.
Jan 27, 2010 | Tools & Hardware - Others
Craftsman 11650 6 Amp 10,000 Rpm Corded 4 Angle Grinder 900.11650 Logo
61 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
