Error 000013 - Office Equipment & Supplies
E-000013-0000
At power-on, the rise in the temperature of the fixing assembly is not high enough. The main thermistor (THM1, THM2, THM3), thermal switch (TP1, TP2, TP3), or heater (H1, H2, H3, H4) has an open circuit or poor contact. The AC drive PCB or the DC controller PCB is faulty.
The temperature reaches 110 deg C, but does not reach 140 deg C within 300 sec. Remedy Check for an open circuit and poor contact in the main thermistor, thermal switch, and heater; then, reset in service mode: COPIER>FUNCTION>CLEAR>ERR.
Dec 09, 2014 | Canon ImageRunner 5050N Digital Copier
What is the problem of error code 000013-0000
Thanks a lot , i can clear error code e000 of ir2010 by your solution ,I press *function and # and arrow to #7 press ok and #4 printer reset press ok
Dec 17, 2013 | Canon imageRUNNER 2010F Copier
Error code E-000013-0000 on a Canon Image Runner 5000
e-000013, it is all about waste toner.
possibility :
- waste toner case was detecred full.
- The PLL lock is released because waste toner motor is locked up, etc.
- The micro switch employed to detect clogging of waste toner is activated.
the position behind-below of copier.
open the beck cover and you ll see it.
the waste toner case
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
When i get my c3100 started i get an error code e 000013-0000 . can you tell me what the problem is
Waste toner bottle full, open front door, one screw, make sure small cut out in the neck of the bottle is clean afterwards.
Oct 31, 2010 | Canon imageRunner C3100 Copier
Error 000013
E 013 is waste toner full. drop open the front door, you should see the bottle. now look for a single screw in the cover at the top of the bottle. remove the screw and bottle. dump the bottle in a thash bag. there is a light that shines thru the neck of the bottle, that path has to be clean. pull off the clear tape andplastic cones and blow out as much toner as you can and reassemble. don't wear white :) rp
Mar 21, 2008 | Canon imageRunner C3100 Copier
CANON 5870 ERROR CODE
its mean that wast toner box is full,empty waste toner box
Sep 25, 2007 | Sharp AR-C160 Color Copier
15 people viewed this question
jasbo
jasbo
