Question about Dishwashers
Simpson 950 Our Simpson Silencio 950 not draining water out causing strong odour 24/10/11 was reported as same issue. Would we need a service man
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
No, most likely you need to add rinse agent and/or dishwasher salt to your dishwasher for it to run properly. If you have recently put in something with a label and it came off in the heat the paper would now be blocking the filter and you should check this too, it would be reachable through a screwtop inside the main body of your dishwasher. If the clog has formed inside the tube that leads out of your dishwasher you could disconnect it and run hot water directly through, you may be more comfortable with a service man but it is really something anyone can do without much need for tools except for a bucket and old junky towels handy in case of slight spillage. Best to turn the electric and water off to it first!
Posted on Nov 21, 2013
SOURCE: Simpson Silencio 850 leaks -
Hi, I've just purchased a 2nd hand model of your dishwasher. mine actually leaks from the black lining underneath. I've just patched it with some Sellys bathroom sealant. I don't know more about your problem but sounds like it could be something not timing out to stop the water, maybe buy a new 1 :P
Posted on Sep 18, 2008
SOURCE: simpson silencio 850 dishwasher. not
Halfway and at the end. Put them upside down on the right-hand side to avoid the tray jumping when sliding.
Posted on May 05, 2009
  • 11 Answers
SOURCE: water will no enter my dishwasher
check out you're hoses.. the mice might have chewed through them. that happened to my sister
Posted on May 30, 2009
SOURCE: water not emptying in dishwasher model simpson silencio 850
How long does it take to wash dishes completely in a ASimpson dishwasher
Posted on Jun 12, 2009
  • 20 Answers
SOURCE: dishwasher simpson (silencio 850) model 52B850SF * 04
Check that the pressure switch tubes are not blocked on the underside of the machine on the right hand side and that the pressure switches are working when you blow down their tubes. You will hear them click on and off.
Posted on Dec 23, 2010
Hi i have a 9.5kg simpson washing machine error code PU31 what does that mean as my machine is not spinning out washing
Pump error. It means drain pump is either blocked or faulty. Water is not draining out or very slowly. Water has to all drain away before the machine will spin. Get the water out by lowering the drain hose down into a bucket. When machine is empty then remove and check the drain pump.
Dec 24, 2016 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
My Simpson exist set 950. Why does it overfill and pour water on the floor?
it sounds like your water level clip is broken and needs replacing
Jun 01, 2015 | Simpson Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Simpson silencio dishwasher over filling . have c...
Clean the filters and filter bowl and if that doesn't solve the problem check the pipes to the pressure switches on the bottom right side (as you face it ) are not blocked and check that the pressure switches are working by blowing in their tubes and checking for a "click" sound and test with a multimeter for an open and closing circuit.
May 20, 2010 | Dishwashers
Water will no enter my dishwasher
May 30, 2009 | Dishwashers
Water not emptying in dishwasher model simpson silencio 850
Apr 18, 2009 | KitchenAid 24 in. KUDI01IL - Multiple...
Dishwasher simpson (silencio 850) model 52B850SF * 04
Nov 05, 2008 | Dishwashers
Dishwashers Logo
121 people viewed this question
Top Dishwashers Experts
