Question about Cerwin Vega AVS-5.1 System
How do i set up the cerwin vega avs sub8 - Cerwin Vega AVS-5.1 System
3 Suggested Answers
  • 5 Answers
SOURCE: what is the omhs of
According the the Cerwin Vega manual for this model and others, all speakers in the system are rated at 8ohms. This includes the Sat4 Surround Speaker and all other channels.
More information can be found at Cerwin-Vega's service and support page at: http://www.cerwinvega.com/product-manuals.html
You can also call them for information as well.
Posted on Mar 19, 2011
SOURCE: cerwin vega avs sub8. no power. changed blown fuse
I got the same problem, my sub was working perfectly and suddenly one day it did't turned on, so I think it is the protection from the internal transformer, it needs to be changed but I don't know the model, if someone else knows I would appreciate the info because it is a really good subwoofer for the size...
Posted on May 02, 2011
Does anyone have a manual for my product
go to this site, select appropriate and download:
http://www.cerwinvega.com/cerwin-vega-product-manuals.html
do not forget to vote...
Apr 04, 2015 | Cerwin Vega AVS-632 System
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
What is the omhs of a cerwin vega avs sat4 surround speaker
Mar 19, 2011 | Cerwin Vega AVS-5.1 System
Cerwin vega avs sub8. no power. changed blown fuse and still nothing. no power light indicator. unless led light bulb blew which i believe to be unlikely it has no power. any ideas
Jan 07, 2011 | Cerwin Vega AVS-5.1 System
Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Jul 05, 2010 | Cerwin Vega AVS-5.1 System
No sound coming out of speakers on my cerwin vega
spurdoggg,
It will be easy to pin point the problem. If your satellite speakers have been connect through the sub's in and output speaker connectors, disconnect them and connect them directly to the source of sound. If the speakers work its the crossover inside the sub enclosure. If the speakers do not work the speakers are blown.
Apr 28, 2010 | Cerwin Vega AVS-5.1 System
Sony SRT-DE595
go into the speaker setup menu and turn subwoofer to YES
Dec 08, 2008 | Sony STR-DE595 Receiver
Cerwin Vega AVS-5.1 System Logo
43 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
