Question about Hardware & Accessories
Celsius Digital Timer 9421025628917 instructions please
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
Help programing or instructions for indoor timer TM-020 E227659
Live answer 11-24-12
The only TM 020 timer I show is 230Volt 50 hz Chinese analog-type timer. This timer is not digital.
http://waterheatertimer.org/Woods-timers-and-manuals.html#49664
http://waterheatertimer.org/How-to-set-timers.html
Over past 2 years, I have requested several times that person asking question about TM 020 please include full description of timer buttons and relevant features, and/or post photo of timer on flickr and add link to that photo, so the timer can be clearly identified and possible manual found using timer with same-similar features.
Please add a comment
Nov 13, 2012 | Hardware & Accessories
Usually coolant temp would increase from 75 celsius to 100 celsius with engine running.The coolant engine gauge is not rising from 75 celsius with the engine running.
Hi, it is likely your thermostat is stuck open. I recommend replacing the thermostat. If you need instructions, please reply with model, year, and engine size.
Jan 05, 2011 | GMC G3500 Cars & Trucks
What temperature will this timer operate at. I have a outdoor application where the temperature could reach -10 degrees f. Will this timer still function?
ST01C is battery operated timer.
Timer programming will cycle without being connected to electricity.
CR2 lithium battery specs say operating temperatures are minus 20 to minus 40 degrees Celsius. That is minus 4 to minus 40 degrees Fahrenheit. With expected service life reduced to 1 month when battery continuously exposed to temperatures at low end.
So it looks like ST01C will operate correctly for some outdoor application, but will shorten lifetime of battery.
I will add that ST01C has 1 year limited warranty, and folks write in about timers that don't function after replacing battery.
Of course people don't write in when timer functions correctly after replacing battery.
Dec 07, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Cdw12 instructions
I just moved into an apartment with a celsius cdw12 dishwasher and i don't have the manual Can anyone help me?
Nov 22, 2009 | Dishwashers
Setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
Feb 02, 2009 | Woods Industries 59377 Indoor Digital...
Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Oct 31, 2008 | Hardware & Accessories
Hardware & Accessories Logo
76 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
