Suyama generator I have a Suyama diesel 178FA and I need a new head gasket,can anyone tell me where I can get one please. malmcnab@hotmail.com
4 Suggested Answers
Buschchris1
  • 474 Answers
SOURCE: hi my lcd suyama 17"
Its not getting a signal from your video card or onboard video.
Are you connected by a VGA cable or a DVI Cable. Or does it have an adapter from VGA to DVI?
Check and see if the moniotr it set to DIGITAL instead of ANOLOGUE. If so, switch to the other.
If you press the monitor settings buttons, does anything show like options to adjust contrast?
If so then it most likely your computer.
Posted on Apr 15, 2008
  • 90 Answers
SOURCE: my 17 inch suyama computer
Resolution problem set the correct resolution
Posted on Mar 25, 2011
  • 42190 Answers
SOURCE: not lawn trimmer but generator it's a Suyama power serve 5500 air cooled generator 12.5hp pull start need carby kit
as most carbies are generic in nature ( made by a small number of manufacturers ) talk with a mower shop as to parts availability
if you can get a name of the carby and if possible a number , you could get complete new carbies from e-bay
If I remember rightly this would not run when the choke was put off
if that is correct , there is a problem of a blocked main jet or insufficient fuel flow to the carby
the fuel tap is probably metal and if so , they corrode up inside and block the flow
comment as posts are not linked and the answer thread is lost
Posted on Oct 02, 2016
How to tell if a gasket is bad on a ho.elite generator
Head gaskets are only tested when hot and under pressure with a cylinder leak down test. Intake gaskets are tested using a spray like wd40 and listening for engine change. Exhaust gaskets are tested best with a carbon monoxide tester.
Feb 17, 2017 | Electrical Supplies
Not lawn trimmer but generator it's a Suyama power serve 5500 air cooled generator 12.5hp pull start need carby kit
Oct 02, 2016 | Garden
I require a head gasket
go on the net to the manufacturer of the diesel and find the parts catalogue and order from there or a local dealer for that engine.
Mar 17, 2014 | Cars & Trucks
How do i tell if i have a cracked head on a 1990 nissan terrano diesel
Have a coolant pressure test done and compression test done. There is a real possibility of a cracked head but you may be lucky with just a warped head and blown gasket.
Mar 29, 2013 | Cars & Trucks
What kind of diesel engine in a 1984 Ford Econoline Class C RV? Are these engines known for head gasket problems and should a rebuild have fixed that?
What you have is a Navistar 6.9L Diesel engine in your van-RV.
They are know to blow head gaskets----nomally its a matter of taking the heads off --clean everthing --check for unusual large crack in the glow plugs pre-cups, check heads for flatness and than slap the heads back with new head gaskets.
This engines if the normal maintenance was done regularily they will do a easy 300,000 miles--with the head gaskets replaced when needed.
the easiest way to check for this is look for bubbles in the coolant resorvoir bottle with the engine running.
Also the other most important thing is make sure that the cooling system is clean--means new coolant on schedule and radiator removed and have it rodded --cleaned out.
You can tell if it needs rodding by draining a little coolant -enough that you can see the tube ends thru the radiator cap neck --to see if they are plugged or open.
Nov 20, 2009 | 1984 Ford Econoline
19'' Suyama monitor
There are problem with internal component of Monitor might be EHT is faulty .Its better call vendor for repair
Nov 18, 2009 | Computers & Internet
Hi my lcd suyama 17" computer monitor will not turn on. the green light next to the `on` button flashes but apart from that there is no life at all.
Apr 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
