Question about Worldwide 1996 Ford E250 Econoline 5.8L Alternator
Oil pressure gauge went out but van runs fine?
Oil pressure gauge started flickering then went out. didn't seem to lose pressure, ran on the hwy for 15 min after went out then idle in driveway 15 more. am I sure I didn't lose pressure, just a sensor?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Just a sensor, or gague
Posted on Nov 21, 2013
Gmc sonoma has no power but a good battery
This sounds like a bad ground. check all the heavy gauge cables attached to the frame. If one is loose, it will arc under a load, but lose its continuity.
Nov 10, 2013 | GMC Sonoma Cars & Trucks
I just purchased a 2000 GMC Savana 3500 with the 5.7 litter engine with 92000 miles on it. The temp gauge shows that the engine is running between 100 - 160 degrees, seems too cold. The oil pressure gauge...
you probably have your finger on the problem. have oil pressure test .when engine hot minimum 12psi.and change the thermostat.Don't cost much
Sep 16, 2013 | 2000 GMC Savana
2001 crown victoria lost oil pressure and just cut off now when i start the car after five mins the car start ticking really loud
i have a 2001 crown victoria was driving down hwy car made loud noise and shut off had it towed home got it started and has NO power almost couldnt get i in drive way, had been making a slite noise before that and bucking
for about 4 months in the last 3 weeks noise was getting louder. Was told could be timing chain how likely is this and how do i check it.
Sep 30, 2012 | 2001 Ford Crown Victoria
Ok, 2003 GMC Safari AWD 245,000 km. Drove 100km
sounds like an ignition switch glitch or ignition harness problem can be either depending on the amount of wear and tear with turning on and off of the ignition tumbler or possible chafing or inconsistent short in harness to ignition switch check the ground line up through harness first and check the wiring harness condition
Jan 03, 2011 | 2003 GMC Safari
O2 lincoln ls check engine light & fuel gauge went to empty the next day it wouldny start replaced fuel pump & fuel gauge ran fine drove about 40 miles the next day started it up check engine light...
You have two pumps,I guess you know that ,if you already did one. Did you check fuel pressure at the rail and check out the electronic pressure regulator? What codes are coming up and do they stay set?
Feb 05, 2010 | 2002 Lincoln LS
Possible oil pump problem
You need to determine if the engine has lost oil pressure (assuming the oil level is good) You need to place a mechanical gauge where the oil sending unit is that goes to your gauge. If this gauge reads low, you have an oil pump problem. Keep in mind that gauges and sending units can go bad. But the loosing power doesn't sound good. Start here to determine what is up.
Aug 20, 2009 | 1995 Chevrolet Camaro
2002 2.5l no oil pressure on gauge. Runs fine...no
You better put a manual gauge on your engine and make sure you have oil pressure. Could just be a faulty gauge or sending unit but I sure as heck would be checking it with a manual gauge.
Aug 01, 2009 | 2002 Jeep Wrangler
OIl pressure light flickers
change the oil pressure switch or the wrong oil
Jan 18, 2009 | 2001 Chrysler Concorde
Testing fuel pressure
the port is on the fuel rail on top of the motor. it looks like a big air valve that you find on the wheel.
Nov 09, 2008 | 2002 Kia Sedona
Worldwide 1996 Ford E250 Econoline 5.8L Alternator Logo
53 people viewed this question
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
