Question about Samsung Televison & Video
Screen is blackened on top of screen
About 4 years old version aa01. bottom of screen is fine, just the top half is blackened out. you can still see the picture some. tried to reset and go back to default settings. Samsung said someone would have to come out and look at it. expensive tv but have not been able to get any help yet. is it a curciut board or and other electronics I can replace on my own or do I have to call someone to get this issue fixed.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Assuming your TV is an LCD, there is an issue with the CCFL lighting tube/s and one or more needs replacing/repairing.
if your TV is LCDLED then there is an issue with your LED lightstrip - probably faulty circuitry and would need replacing.
unless you are confident with stripping your TV (which i doubt) then you will need to pay someone, and it will probably cost LESS to just buy a new TV -- they are getting very cheap.
Posted on Nov 21, 2013
  • Melissa Klimasewiski
    Melissa Klimasewiski Nov 21, 2013
    what about the buffer board we see so much talk about. and yes it is an lcd. I am not workng so need to try and fix it myself. can not afford a new tv or a repair person.
    when i do the factory reset and it ask me if the picture looks fine and the picture it shows is in its entirety, but when it goes back to the actuall tv screen it is black again.
4 Suggested Answers
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
  • 718 Answers
SOURCE: Insignia TV suddenly no sound
Go into the SOUND section of the menu. Find the TV Speaker out option and make sure its on.
Make sure the VOLUME is not set to zero !!
Posted on Feb 23, 2009
SOURCE: LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Posted on Jan 04, 2010
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
TV Blinks on and off
Phil, from your description it sounds like your convergence IC`s are about to fail, the intermittent off/on cycle is because as they heat up there drawing too much current, the bowed collapse tells me it`s the vertical convergence IC that`s the culprit. You need to get a tech out asap to fix this or they could short and take out the power supply as well and that`s just mooore money to fix it, hope this answers your question, BMW Rider
Dec 05, 2007 | Hitachi 43FDX15B 43" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Half a screen
The picture on your TV screen is driven from the center to the top and bottom of the screen by the vertical drive circuit. The fact that you can see the entire picture means you have a problem called foldover. This is caused by a failure in the vertical drive circuit where the vertical saw signal is altered by a component failure within the vertical drive circuit. You cannot solve this problem but any good repair shop should be able to correct the problem at a reasonable cost.
Jun 22, 2006 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Televison & Video Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
