Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
How to install handle / wand cap - Dyson DC07 Bagless Upright Cyclonic Vacuum
How to install the wand handle catch
If the wand keeps coming away from the machine then it is likely that on the back of the machine the four pegs that hold the wand in place 1 or more are broken.
If this is the case then the fault is not the wand but the spine of the machine. You would require a new or sevond hand spine and it would mean completly stripping it.
Apr 02, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Install wand handle catch
You line up the spring, place the two top prongs behind the lip on the wand and gently snap it home onto the two locating pins. You can also now get a workshop manual for the DC07, it is item number 0955687411 on Amazon.
Wand pulls out but sticks when there is still about 2 inches to go before able to close cap on wand
You might have an obstruction somewhere or something is keeping a valve that directs the airflow from the floor to the wand from moving properly. You will need to investigate all these areas to determine what is nor operating properly.
Feb 23, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Lost my manual to "Animal". Need to know how to
The manual is located on the below link.
http://dl.owneriq.net/6/6b31ee20-0d21-3fc4-6d61-0e7daeb1dd56.pdf
Place wand in upright position.
Press release catch and slide wand to end of hose.
Slide wand cap back and place wanted tool on handle.
This information can be found on page 10 of the manual.
Mar 01, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson animal 25 wand won't go into tube
We have a DC65 Animal, the extension tube on the hose would not slide into the top of the handle.
The solution:
1. Slide the hose into the cradle on the handle
2. Push the tube down close to its stowed position
3. Near the bottom of the hose, gently push the hose against the handle with one hand and then push the tube down with your other hand
4. Close the cap on the top of the handle
Feb 02, 2011 | Dyson DC25 Animal Bagless Upright Vacuum
Looking for part PA6 (cap end on telescope handle)
http://www.ebay.co.uk/itm/GENUINE-DYSON-DC15-WAND-HANDLE-CAP-STEEL-908225-05-/310269395401?pt=UK_Vacuum_Cleaner_Bags_Parts&hash=item483d7f41c9
Feb 01, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The wandcap for my dyson vacuum doesn't stop the air from flowing though the wand. If your first responce is what model dyson ---then don't bother responding.
The cap on the DC07 should allow air to flow through when the handle is in the upright position. When you pull the handle back, there shouldn't be suction in the handle.
Jun 27, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I can't figure out how to hook up hose attachment to dyson 07
You have a reversible wand on the DC07. You have to separate the wand from the hose first, then turn it around and reconnect it. Once that is done you will be able to use the attachments on the end of the wand. You can also connect your attachments to the hose.
To separate the wand:
1) Take the wand off the back of the machine
2) Place one hand on the Handle and one hand on the gray flexible hose.
3) Push the flexible hose down. You will see a long metal rod appearing. Push until the hose clicks into place at the bottom of the metal rod.
4) You'll see a half-moon shape button with a picture of a lock on the solid gray plastic part at the top of the hose - push it, this will separate the wand from the hose.
5) Turn the wand around
6) Push the purple wand cap with the holes in it back, it exposes a short dark gray pipe, about an inch in length
7) Connect the hose to the short pipe
8) Attach your tools to the top of the metal rod and have fun
Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum wand won't retract fully into it's compartment.
HI,
FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
REGARDS
DAZ
Dec 12, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell 1698-1
the heater is blocked wih lime scale
Aug 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
21 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
