Question about Binks Paint Spray Gun Repair/rebuild Kit For Model 2001
Paint gun splatters paint on car
When the gun was new it worked fine tried to paint my hood and paint comes out rough and looks as if it were splattered on rather then sprayed
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
The needle valve in the spray head needs to be cleaned or replaced.
Posted on Nov 21, 2013
4 Suggested Answers
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Posted on Apr 02, 2010
  • 15 Answers
SOURCE: my binks 18 spray gun squarts paint from the hole
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Posted on Feb 28, 2011
How can I remove paint splatters on fender?
Check out this video on Youtube, which might help:
Hope that helps!
Sep 29, 2016 | 2014 Mazda 3
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
Feb 10, 2012 | GE Microwave Ovens
Hey yall i got a sharpe finex3000 hvlp spray gun model sh-880 1.4 finish gun. and ive used this gun before and i cant remember how 2 set it up etc or what the best working pressure is. anyways i was tryen...
There is a step by step description in the manual of the Finex3000 itself (incl. pressure set-up, etc...). In case you don't have it anymore, you can look online: http://sprayfinishingstore.com/manuals/
Jul 25, 2011 | RTO Sharpe Finex 3000 Hvlp Gravity Auto...
Blowing paint out trough cup
It is clogged and needs to be disassembled and cleaned with MEK. methyl ethel ketone
Aug 01, 2009 | Air Tools & Compressors
IR 210g - using thicker paint
i dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Nov 19, 2008 | Ingersoll Rand Hvlp Automotive Spray Gun
Vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Nov 17, 2008 | Northern Tool Vaper 2.0mm Hvlp Spray Gun...
How to smooth exterior stone window sills and lintels
try using unsanded grout. you may want to use a bonding agent to make sure it sticks. home depot or lowes. If you want a rougher finish use sanded grout. You should scrape surface down to bare stone. Some times a heat gun will loosen the paint. Use a mask as the paint may contain lead.
tom
Oct 18, 2008 | Tools & Hardware - Others
Binks Paint Spray Gun Repair/rebuild Kit For Model 2001 Logo
131 people viewed this question
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
john h
russ davis
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
