Toshiba 32in tv sound keeps cutting out
New toshiba 32in tv when in operation the sound will cut out but then it comes back on
    Top Expert:
  • Televison & ... Master
  • 74,232 Answers
It sounds to be a speaker fault. Check it.
Posted on Nov 21, 2013
SOURCE: no picture but has sound
we had the same problem and took it to be repaired and they said it was just a,loose connection
Posted on May 31, 2008
your bulb has burnt out
Posted on Sep 09, 2008
hey i think i know your solution on how to fix that you should get another tv lol jp go to my web site and I'll tell you a couple of methods to try.its meatspin.com
Posted on Feb 28, 2009
ginko
  • 19396 Answers
The problem can be caused by a bad sustain board (Ysus Zsus) , the popping sound is often caused by a capacitor blowing up.
The TV must be taken apart and tested before eventually replacing sustain boards.
Posted on May 05, 2009
  • 11 Answers
SOURCE: lg 42lb1dr tv cuts off no picture or sound. gray screen.
There are 4 capacitors on the power supply board that need to be replace. They are in the same area, same color, look for bulged caps.
Posted on Nov 03, 2009
The sound on my TV keeps cutting out. It cuts out for 1-2 seconds. It does this approx. every 30 seconds. I have changed cables and cable box....no change. Any suggestions?
Sounds like the final audio amp MOSFETs are overheating.
After set has been off and unplugged check for dirt and dust clogging cooling fins and parts. Air must circulate for cooling. Remove dust with a gentle blast of air or an upholstery brush attachment on your vacuum cleaner.
If this doesn't work the parts usually cost more than a modern set is worth and I suggest purchase a new set.
Nov 26, 2015 | Televison & Video
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
Red power lights blinks and tv will cut off. sometimes after you unplug it it will come on after about 10 min. now it will not come on unless you unplug it and then it will work about 5 min and cut off...
depending on the age of your tv, this appears to be a common issue. Blame it on the ballast board. your ballast might not be able to provide the lamp w/ enough voltage to keep the image on for longer period of times. or it could simply be that you need a new tv lamp.
Apr 13, 2010 | Toshiba 55HX70 55" Rear Projection...
Toshiba tv cutting off
are you going to attempt the repair yourself, do you have a shop manual, and test equipment ? let me know
Jan 30, 2010 | Televison & Video
My samsung tv sound keeps cutting out. I have to
either you have a loose connector going to speakers or the main board is failing.call 1-800-samsung for nearest service center.
Dec 02, 2009 | Samsung LA40A450 40 in. LCD TV
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Tv cuts on and off
This sounds like the flyback on the main circut board needs replaced (part is in 70.00 range!
Dec 12, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
