Question about Canon PIXMA iP4600 Color InkJet Photo Printer
B200 mean printer - Canon PIXMA iP4600 Color InkJet Photo Printer
B200 wont go on line or connect took off cord and still wont work
Error B200 means that there's a problem concerning the Printhead in most cases... in a great 90% of the cases is not fixable but...
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Gently clean the printhead contacts with alcohol.
6. Place the print head back in and lock the lever down.
7. Place all of the ink tanks back in the printer.
8. Close the cover and turn the printer off.
9. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
10. Plug the power back in and turn the printer on.
Jan 02, 2016 | Cannon Office Equipment & Supplies
Canon MP276 show a error number B200. how i solve it?
FIXED: Canon Printer Error B200 With 5 Different Solutions ...
? 3:33
www.youtube.com/watch?v=LZELHKjVZAY Mar 18, 2014 - Uploaded by ITJungles Five different solutions you can try to fix the Canon printer error B200. Is your printer playing up and not doing ..
Jul 22, 2015 | Canon Office Equipment & Supplies
What does error message B200 mean?
It indicates a problem with the printhead. Could be a burned up or choked printhead. Step By Step Guide To Resolve Error B200
Jun 15, 2014 | Canon Pixma MG5220 InkJet Printer
Canon mg5250 -error code B200
B200 usually means that the printhead has failed. It's a generic "overtemperature detected" error that indicates that the thermal sensors inside the printhead have detected heating to the point where the printhead has probably failed. In a well-intentioned attempt to prevent further damage, the printer has shut itself off; however, by the time this occurs, the printhead is usually destroyed. The following video shows a likely next step: http://www.youtube.com/watch?v=I9uBEOMCd44
Jun 05, 2013 | Microsoft Windows 7 Ultimate for PC
I'm getting a b200 error message and I MUST print tonight!
It is referenced on other message boards that the B200 error means "Printhead Temperature exceeded", which can be caused by an ink cartridge running out, yet the printer continues the operation. You could try unplugging the printer for a couple minutes to let it cool down, and try again. If it still has the error, you'll most likely have to send it in for repairs.
May 03, 2011 | Canon PIXMA MP540 All-In-One InkJet...
How do I fix my printer, it is showing B200 error?
B200 error means "Print head Temperature exceeded". In your to solve your problem you need to perform a printer reset. Click Here to view the Canon reset guide or you can follow the steps below:
1) Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press the power button for 1 sec.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again.
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 22, 2011 | Canon PIXMA MP540 All-In-One InkJet...
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 25, 2010 | Canon Office Equipment & Supplies
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
21 people viewed this question
old marine
old marine
