SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
SOURCE: what is error code f9-00 on sharp mx-3501N
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Thanks,
CF
SOURCE: Get network error ce-00 on the sharp mx-3501n when
CE-00 means ther is a bad destination entered or the copier is not seeing the server check the IP address
SOURCE: how to clear error code
If you power the machine off and on and it comes back, try replacing the whole transfer belt unit. If it still comes back, sorry dude you're out of luck. Your copier can't swing the hinged portion of the transfer belt on and off your color drums because a badly designed gearshaft for your transfer lift motor has worn out and probably ate up a bearing or bushing as well. This is a known problem and Sharp has published a service bulletin addressing this. It may be motor rebuild time for you, with the new edition gearshaft.
