Question about Singer 8763 Curvy
Needle position On my Singer 8763 Curvy, how do I set my needle to stop in the down position instead of the up position? I would like to applique and need my needle to stop down when I release the pedal.
    Champion:
    Habit-Forming:
  • 201 Answers
Please correct down position and remove the foot and switch off machine. Then set of the up position applique the needle. After machine On.
Posted on Nov 21, 2013
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
chris592
  • 86 Answers
SOURCE: I need instruction and project manuals.
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=687&option=com_virtuemart&Itemid=54
Posted on Nov 16, 2010
bugoy31
  • 1238 Answers
SOURCE: my singer curvy 8780 has
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on Jun 06, 2011
SOURCE: SINGER CURVY: It jammed while sewing felt. Taking
the thread keeps gathering in big bunches under the material~i adjusted the tension but still gathers~Im wondering if there is something stuck wonder the plate~THanks
Posted on Jun 22, 2011
t_klefever
SOURCE: I have Singer Curvy 8763.
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Posted on Jul 15, 2012
Does the singer curvy 8763 have a needle down featu9
The specs for the machine do not state it has needle down function. If it does, the manual should discuss it,.
Aug 04, 2017 | Singer Sewing Machines
I buyed a new sewing machine curvy 8763 and when i start trheading the bobbin the needle stats working as well and it starts beeping
Consult your owner's manual. There is a handwheel release that, when loosened, will allow the bobbin to wind but stops the needlebar trying to stitch.
Oct 24, 2015 | Singer 8763 Curvy
I have a singer curvy 8763 and the needle id dragging in the bobbin wheel. Tried changing the needle and making stitch adjustment.
insert the needle all the way up. if it is not a timing issue, try to lift the needle shaft
Aug 09, 2014 | Singer 8763 Curvy
I have a singet curvy 8763 and the needle id dragging in the bobbin wheel. Tried changing the needle and making stitch adjustment.
insert the needle all the way up or, lift the needle shaft and, if the problem persist's andjust the timing of the machine
Need a open darning and walker foot for my curvy 8763 which should i purchase?
A Curvy isn't an Athena. I have a Curvy and it is a low-shank machine that can use a variety of snap-on feet.
Mar 15, 2013 | Singer 8763 Curvy
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
I have Singer Curvy 8763. It seems that the foot control stopped to work. The machine does not sew, its impossible to wind the bobbin. It is possible however to sew backwards with the help of reverse...
Nov 04, 2010 | Singer 8763 Curvy
Singer 8763 Curvy Logo
268 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
