Question about Air Tools & Compressors
Husky h1512fwk how do i remove top - Air Tools & Compressors
How to replace broken trigger on a huskie 162 sg chain saw
Most Husky saws have a small pin to drive out to remove trigger. Often safety lever on top needs to be removed also. Sometimes tank/handle assembly needs to be removed to replace trigger.
Dec 27, 2016 | Garden
I have model Husky WL651004AJ it will not run at all. I want to remove the top cover to check the electrics. I can get the cover off. The snaps come loose, that's as far as I can get. How do you remov
I have a Husky WL651004AJ which has not been starting up for family members lately and noticed a 50 ft extension cord was being used because of the distance from the power outlet. I moved the air compressor to the power outlet and plugged in the power cord without any other extension cord and the air compressor works fine. The 50 ft cord was too light duty for the power required.
(12 ga) and min gage of 10 for the distance of 50 ft without disrupting the power breakers.
Dec 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
How do i take the oil tank off a 41 cc husky chain saw
I guess we are talking about the Husqvarna 41/141, start by removing the guide bar and chain, remove top cover, disconnect and remove the throttle wire, remove the fuel hose from the carb, use a 4mm allen key and remove the front anti vibration rubber screw ( drive side, bottom front r/h, holding the alloy chain catcher ) now remove the top anti vibration rubber screw with a cross head screw driver ( top l/h holding an orange plate ) now remove the four screws securing the starter cover, two screws are into the plastic crankcase, and two are into the anti vibration rubbers, the fuel tank should now pull out from the bottom of the saw withe top handle still connected, make sure the fuel hose feeds out of the crankcase as you pull the tank away.
Feb 10, 2011 | Garden
Piston seizure in Husky 359 chain saw-how to remove old top end, evaluate damage and install new piston and ring or all new top end.
Probably going to be a paired piston&cylinder http://www.ebay.com/itm/HUSQVARNA-359-357-CYLINDER-AND-PISTON-KIT-47MM-/140580138020
you will need to replace both.. remove your muffler and see scorched(black streaks) piston, fused rings. Remove air filter and carb to see scored cylinder wall(on hot side)
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
Did Poulan buy McCulloch?
No, Husqvarna owns them both. New McCullochs are almost non-existant in the US of A. I suspect the same is true of Poulan in Europe. The OMs are almost identical. Except for the color the outward appearance is also very similar. Both recommend 40:1 mix. There are to many similarities for them not to the same saw. Sort of like Husky/Jonsered (also owned by Husky). I wish Huskys had the straight top handle. All is clear? no? Me too. LOL
Lou
Feb 10, 2010 | McCulloch Garden
Johnsered chainsaw 625
I think a duplicate question… duplicate answer
This thread says a Jonsred 625 is a Husky 61. Post 17 by SawTroll can be taken to the bank. Everyone defers to him regarding specification questions.
http://www.arboristsite.com/showthread.php?t=103127&highlight=jonsered+625
I found an Operators manual here (no IPL):
http://www.tilton.usa.jonsered.com/node246.aspx
There are a number of model 61s starting on page 11. I suggest you contact Husky for clarification of any saw older than 2000. They may even provide the correct IPL for saw (Jonsered owned by Husky).
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
That said, the 61 has an outboard clutch. This will help you with removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan clutch removal tool part number 530031112 if needed. Under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
HTH
Lou
Jan 12, 2010 | Husqvarna Garden
My Johnsered 625 chainsaw clutch work????
is it a high idle? most chainsaw's chain continues to turn with a high idle.
Jan 12, 2010 | Garden
My hUSKI 395 is stalling when i pull the throttle wont rev
So, it idles ok but when you go for any extra throttle it dies?
Your carb may have a blocked main jet. You can removed your carb and after taking off the top and bottom diaphragms remove the main jet and blow through it with a splash of gas *(no carb cleaner! Some carbs are coated and carb cleaner can strip off this coating. Ruining the carb)
Use compressed air to help clear out the main jet passage and reassemble. Be sure you know how many turns your carb main jet needs to be set at before you remove it! Usually its 1-1/2 turns.
You should check online for a Husky website that may have additional guidance.
Good luck and be careful.
Dec 29, 2009 | Husqvarna Garden
I have a husky compressor, model number y6010-wk. it builds pressure slow, and shuts down right away.
Problem: My compressor is not producing the air that it once did. It takes twice as long to pump up.
Solution:
1)Turn off your compressor or disconnect the power.
2)Remove the connector tube that sends air to the tank.
3)Remove the head bolts on top of the pump.
4)Remove the head off of your pump.
5)Remove the valve plate off of your pump. It may be a one piece or a 2 piece design.
6)Inspect the valve plate for broken reed valves or broken gaskets above or below the valve plate.
Feb 27, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
42 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
