Nideka biometric - Office Equipment & Supplies
  • yuan cabral
    yuan cabral Nov 21, 2013
    "Manager Confirm Menu Log in" what is the problem with this? i didnt set any manager password but the error keeps on displaying?
    please help :(
I forgot password of ls-838 lonestar biometric
The password is present to prevent the usage of it by a thief after it has been stolen.
May 25, 2014 | BestPriceCables Lonestar Biometric Time...
Where i cant get biometric software for win7, because i have biometric software for win xp, thanks & regards
better solution you can run the software in compatibility mode and it will work fine with win 7.right click on the instillation icon click properties on the window you will see a compatibility menu click on it and select the winxp you were using b4 then run the installation
May 21, 2014 | APC Biometric Mouse Password Manager...
Nideka bundy clock
"manager confirm menu login" what seems to be the problem with this? i dont have any manager password
May 19, 2013 | Office Equipment & Supplies
I have a Adel Trinity 788 biometric fingerprint handle that I need to install. I lost the screws and I am trying to find the 3 long bolts that connect the 2 halves together. Does anyone know where to...
Trinity Keyless Biometric lock:
I can't answer your question directly, but I can steer you to their website, which includes a support phone number that you can call, as well as links to Customer support and Frequently Asked Questions:
http://www.axxisbiometrics.com/products/locks/latch-style/trinity788/
I'm sure they can answer your questions. Good luck!
Apr 10, 2011 | Trinity Keyless Biometric Fingerprint Door...
Reader is not connected how do i connect it
You can't thumbprint without scanner but you can be able to thumbprint without problem, if you have the right tool like:
- installing the right driiver of your scanner
- by providing the 16 xter security key
- by having biometric license
All will be history when you have the tool in place.
Do you have your biometric licesne and Jamb biometrics Software
Email us me on biometricmasters2000-jamb@yahoo.com or call 08132829820
Mar 23, 2011 | DigitalPersona UareU 4500 Fingerprint...
Unable to obtain authentication input/output error has occurred. Error while loading applet Module is not registered.
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.
This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks
The Rule is:Help others without charge :)
Jan 10, 2011 | DigitalPersona UareU 4500 Fingerprint...
SentrySafe DA3930 Biometric Fingerprint Safe Item Number 681814 will not recognize my finger print!!!! I have been trying to get into it on and off for 3 months. Is there a reset code???
contact sentry
biometric scanners DO NOT WORK
prove your ownership
and they may assist you
and
Sep 14, 2008 | Sentry Fireproof Safe
k24674
jasbo
jasbo
