Question about Dell XPS 210 PC Desktop
Can't erase drive on dell xps 210 to do a clean install for windows 7
Dvd drive works and is first in boot sequence but won't boot killdisk to erase the drive.
    Novelist:
  • 187 Answers
Hard drive? have to do a FORMAT of drive to clear it. then try install, run any drivers disks before the windows after formatting the hard drive. all will be gone that was, so backup anything you wanted saved.
Posted on Apr 21, 2014
wipdhuls
  • 133 Answers
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
Posted on Jun 11, 2009
  • 1019 Answers
SOURCE: Dell Dimension XPS PC Desktop won't boot
Vista is available in 32 and 64 bit os.
if your system ran xp which was most likely 32 bit. And you have installed a 64 bit version os.
this will be your problem, also Vista requires more system RAM/Memory to run it.
If you get 1 beep at startup, it states the system is ok.
Alternatives are device drivers incompatability.
Check M$ website, regarding vistas minimum system requirements.
Mike @ Compurepair.
zcomputerwiz
  • 92 Answers
SOURCE: Upgraded Studio XPS 435/9000 Ram - Now No Windows 7 Start
Check speed settings in BIOS, make sure that the sticks are the correct voltage for your motherboard. If the specs are correct, try a program like memtest86. This will tell you where the problem is, but it is up to you to find which stick that location is :) Might take some trial and error before you find the defective one!
Posted on Dec 16, 2009
  • 30 Answers
SOURCE: Webcam doesn't work with either Vista or Windows 7 (64 bit)
The driver comes with vista 64 bit. The only thing you need to find is the application for the webcam. Good luck.
http://computerstar.ca/
Posted on Feb 23, 2010
SOURCE: Dell XPS/Dimension and BLUE SCREEN OF Death!!
This happens, Because the hard drive has failed. A DVD has failed, RAM, (As you said) has Failed. There is a Modem fault. There is a Video card fault. The way to troubleshoot is to remove, one at a time and try to boot, starting with, the RAM, then DVD, WiFi card, then hard Drive. A PC will still try to Boot even without a hard drive. But to test fully another hard drive with a suitable Operating System. Or get yourself a "Live DVD" this will work straight of the DVD. This will then enable you to test out every feature. Get UBCD, it is very good and free.
www.ultimatebootcd.com/
Use that link, download and burn to a DVD. Set the PC, to boot, from the DVD, Now insert the DVD and start the PC, boot from the DVD, it is very easy to use and you can, test every part of your system. It may turn out that you will need to do a Factory Restore. The link below will show you how to put your PC back to when you first got it. If you need. You may loose some settings etc.
support.dell.com/support/topics/global.aspx/support/.../document?..
Posted on Mar 24, 2010
Dell xps windows7 home premium, pass word unlock
To reset Windows 7 password with Spower Windows Password Reset, just follow the steps below:
Step 1: Download Spower Windows Password Reset Professional (trial version) and install it in an accessible windows. Spower Windows Password Reset Professional can be installed in windows 2000/xp/2003/vista/7/8/10/2008/2012/2016.
Step 2: Create a Windows password reset disk. You can use Spower Windows Password Reset to create a bootable CD/DVD or USB disk.
Step 3: Set the locked computer to boot from CD/DVD or USB drive.
Step 4: Boot the locked computer from Windows password reset disk.
Plug in Windows password reset disk to the locked computer, and restart it. Wait for a few seconds, Spower Windows Password reset program will start and ready for you.
Step 5: Reset forgotten Windows 7 password with Spower Windows password reset program.
When the Spower Windows password reset program is ready, do the steps below to reset windows 7 admin password:
Mar 11, 2017 | Dell Computers & Internet
How do I replace win 8.1 with win 7 enterprise
If you have the Win7 software discs and the product key you should be OK. I'd backup all of your data, then using the Win7 disc, full format the drive and install Win7. Be sure your BIOS is set to boot from the CD/DVD ROM.
Apr 30, 2014 | Dell Inspiron 1420 1520 1521 1525 1526...
Missing opareting system
When you saw "restart to load windows" are you restarting with a windows 7 DVD in the drive?
If so you may have to press F12 as it boots in order to invoke the boot menu and choose DVD as the temporary boot option.
Then follow the instructions for installing windows.
If you did not receive a DVD with purchase the recovery partition was on the drive which may have been wiped with active kill - you could order or borrow a DVD or install Linux.
Mar 31, 2014 | Dell Vostro 1014 Notebook
Is it possible to format a disk using a third party partition software even before installing the O.S
If we got any bootable cd/dvd like window xp, vista and 7. boot it and go up to drive configuration or selection part of that software then make a format of all the drive (C:,D:,E:)
or
use Active@killdisk
http://how-to-erase-hard-drive.com/
May 08, 2013 | Avanquest 1522 Software - Vcom Partition...
Unistall windows 8 pro
You have to install another operating system
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
or
Formatting a hard drive to erase its contents does not mean the files are necessarily gone forever. Using data-recovery software, someone still could retrieve sensitive data and files from your hard drive even after you've formatted it. Instead of simply formatting your hard drive, use disc-cleaning software to permanently erase its contents. Disc-cleaning programs work by repeatedly overwriting the contents of a hard drive with random data patterns, making it virtually impossible to recover the original files. Download and install the freeware program Active@ KillDisk (see Below). http://www.killdisk.com/downloadfree.htm Click the Windows "Start" button and select KillDisk from the "All Programs" list. Click the check box next to the hard drive you want to erase in the "System Local Disks" menu. Press the "Kill" button. Select the erasing method you want to use from the "Erase Method" drop-down menu. Active@ recommends using the "US DoD 5220.22-M" method. Click "Start" to begin erasing the hard drive. Download and install the freeware program Hard Drive Eraser (see Below). http://www.harddriveeraser.org/ Click the Windows "Start" button and select Hard Drive Eraser from the "All Programs" list. Check the radio button next to the hard drive you want to erase under "Select Drive to Erase." Select the erasing method you want to use from the "Shredding Scheme" drop-down menu. The developers of Hard Drive Eraser recommend "DoD 5220-22 M" Press the "Start" button to begin erasing the hard drive. Download and install Iolo DriverScrubber (see Below). Click the "Windows" Start button, "All http://www.iolo.com/ds/3/ Programs" and then the DriverScrubber program icon. Click "Wipe all contents of a drive," and then click "3.5-Inch Floppy Disk." Insert a blank floppy disk and click "Next." Restart your computer with the floppy disk still inserted. Your computer will boot directly to DriveScrubber. Press the down arrow on your keyboard to highlight the hard drive you want to format in the "Available Physical Drives" menu. Press the space bar to select the hard drive. Press "Enter" to continue. Press the down arrow to highlight "Seven Overwrites" in the "Available Data Wiping Methods" menu, and then press the space bar to select it. Press "Enter" to continue. Press "CTRL," "ALT," "Shift" and "W" at the same time to wipe the hard drive. Hope this helps.
b>
Dec 30, 2012 | Dell Computers & Internet
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
My dell laptop model is dell xps1530 .i want to install win 7 but my internal dvd drive is not working i can used external usb drive with instalation but i dont no how in boot form usb booting
1. In case you want to perform a clean install (format hard drive and install a new windows...note that you will lose data so i suggest doing a back-up first), connect your usb drive to your laptop and put in your cd installer. Restart your laptop. When you see the dell logo, press F12 then release. (you have to really watch for it as the alloted time to do so is very small as you may have already noticed.) keep doing the press and release on the F12 key until a boot menu appears. Use your arrow keys to select the boot device to boot from (in this case, your external dvd drive)...
2. If that does not work, restart your laptop then go to the setup by pressing F2 when you see the dell logo (again, you really have to watch for it). when you are in, use arrow key to navigate to "system". press enter to expand the selection. Then use the arrow key again and select boot sequence. press enter. on the right side of the window, you will see the list / boot sequence. use arrow key to select usb external storage device. Then press U to move it to number one (see bottom screen for menu on navigation). When it is on number one, press enter. This will take you back to main menu. Press Esc key then choose save and exit. Your Laptop will then restart on your usb drive...watch for the "press any key to boot from cd..." then follow the instruction on windows 7 installation. Hope that helps...
Apr 22, 2011 | Dell XPS M1530 Notebook
Does dell xps 210 support windows 7?
It is compatible with windows 7. If you want to double confirm, click here and type in your model tag on the bottome
May 09, 2010 | Dell XPS 210 PC Desktop
have you tried changing your hard disk drive? if not, try to change your hard disk drive. then start installing new windows.
Mar 24, 2010 | Dell Dimension XPS Gen 4 PC Desktop
Erased hard drive, now nothing will load
Check to make sure that your Inspiron is set to boot from the CD-ROM drive.
It sounds like your laptop is trying to boot from the (now erased) hard drive first, finds that it can't, then stops without ever checking the CD-ROM drive for boot media.
At startup, hit F2 to go into the BIOS settings. Look for the "Boot Order" section. Make sure that your CD drive is listed first, then your hard drive.
Save your changes, and reboot with the WinXP installation CD in your drive. Now your laptop should boot from the CD and begin installation.
Good Luck!
*If you find the solution helpful, please rate it!*
Jun 04, 2008 | Hitachi TravelStar DK23EB Series DK23EB-40...
Dell XPS 210 PC Desktop Logo
50 people viewed this question
Alun Cox
