Question about Sony KDF-E55A20 55 in. LCD Television
No image and audio for a few seconds
TV working fine, at one point video and audio goes off, black screen, after 30 seconds everything reappears
    Top Expert:
  • Sony Master
  • 43,012 Answers
Your TV has symptoms of power supply trouble.
Posted on Nov 21, 2013
SOURCE: Sony KDF-E60A20 HDTV
I purchased a new Lamp, but before I had time to install, the problem stopped occurring. I feel that this may be a lamp overheating problem due to dust or temperature and humidity within my house. I was going through power outages due to IKE at the time that this problem showed up. At least I have the replacement bulb to try if this problem shows up again.
Posted on Oct 09, 2008
frcs68
  • 1605 Answers
SOURCE: every 30 sec I loose audio, 5 more sec and my screen goes black, instant reset then the cycle starts again
it is your HD box. get another one.
Posted on Oct 10, 2008
welcomejee
  • 10594 Answers
SOURCE: HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
Posted on Mar 07, 2009
  • 80 Answers
SOURCE: Blacking out for 20 seconds over and over
The lamp is going bad. Very common for some Sony to do exactly what you are describing.
Posted on May 21, 2009
SOURCE: screen goes dark, sound goes quiet...
I have a sony KDF-E60A20 projection tv. The picture would go out for about 30 seconds and come back on. It would continue to cycle this way. The green power light would stay on and not flash. The sound would go off when the picture went out and come back on when the picture came back on. I tried taking the bottom cover off the back exposing the fan and blowed it out with a vacuum cleaner, also taking out the bulb and blowing it out. That didn't help. So I ordered a new bulb from Advancedlamps.com and that's what it was. I have now had it on and off for two days and no problems. Cost of lamp was $107.00 including shipping. Good Luck!
Posted on May 29, 2009
TV was working fine earlier today. Now, when the TV is turned on, audio and video will be fine for the first 30 seconds, then everything goes black and audio cuts out. When this happens, a faint buzzi
this works for me.....hold down the off button on top of the tv for at least 5 seconds....(not the remote).....then try the remote on button
if it does not work the first time....try holding down the tv off button a bit longer
Jan 02, 2015 | Panasonic PT-56DLX76 Television
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV display is black; audio works fine. If I turn TV off and then back on the picture does display for a few seconds but then...
The backlight inverter which is also part of the power supply needs to be replaced. If you feel comfortable you can replace the blown capacitors on it.
Feb 10, 2018 | Televison & Video
PS3 problems At home I have a new samsung hd 1080p TV that I normally use for my PS3. I will be in a hotel outa town for the next couple of days and I wanna watch a movie using my PS3. In my...
I had the same problem, stuck in a hotel room for 2 days. When I held down the button, next time I turned it on, I got the same prompt with using HDMI output, said yes, and screen went black. However, a screen then came up asking if I could see the image or not, but it has a 30 second time limit before it saves those setting, you have to click "No" on this screen, and it will drop the resolution to 780p instead of 1080 and it should work! Make sure you're paying attention so you don't miss the screen!
Nov 13, 2010 | Sony Playstation 3 (PS3) Console
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Video warps on edges then cuts out to black, then fades back in
Please dont rate me if could not fix your problem. Check the tv lamp. If doest work well, replace it. Thank you..
Nov 29, 2008 | Samsung TXM3096WHF 30" TV
Screen goes blank, audio still works
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Oct 26, 2008 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Sony KDF-E55A20 55 in. LCD Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
