Question about Haier XQB40-F Top Load Washer
Need manual water level parts
Check water level
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Radiator overflow catch tank question on 2007 WR450f WR 400 426 450
Changing Coolant on Yamaha WR450F 5QJ8H
Yamaha WR450FR Owner Service Manual
OEM parts for Yamaha
YAMAHA WR450F Owner Manual
Jan 26, 2014 | Yamaha WR 450 F Motorcycles
How to check water level for my 2002 Honda GL1800 Goldwing@
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
gl1800riders com
Help Checking coolant level
Honda GL1800 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GOLDWING GL1800 Owner Manual
Sep 01, 2012 | 2002 Honda GL 1800 Gold Wing
The cut off system for the water level no longer works and it overflows if you dont manually move the knob forward
If the appliance works when you move the knob forward it means that the timer work is working and that the inlet valve is not stuck open. In that case the problem is the water level switch that does not cut off when water level reaches the limit. The water level switch is a pressure switch.
Replace the water level switch. before replacing the switch you can check its connectors and try cleaning the rubber hose attached to the switch. The pressure switch is located in the control assembly and is part nr.10 in diagram below:
Here the part for the model indicated in title:SWITCH PRESSURE (Pressure Switch)
Aug 20, 2011 | GE WDSR2080D Top Load Washer
1. I need a service manual 2. how do you raise the water level of the machine
The water level sensor is a pressure switch and there is setting to which as the water gathers into the TUB the pressure exerted on the diaprgram within the pressure switch will correspond and determine the point of switching. So to increase the level within ( make sure that the switch is working as a damaged pressure switch will REQUIRE more water pressure to switch -- faulty diaphragm.)
To increase the level you can set the diaphragm controller to a higer setting-- this provision is seen on most pressure switches so that a higher pressure is needed to switch on thereby the water level goes higher.
Jul 31, 2011 | LG WM3885HCCA Washer
When washing machine fills with water to rinse, the water does not cut off.
Easy fix. No parts needed. All washers have a water level switch of some sort.
Each switch has a small rubber tube attached to it. The tubing goes down under to the base of the tub. As the water level rises the pressure builds inside that tubing. When the desired level is reached the switch kills the water works and starts the motor works. Off she goes a washing. What you must do is find the water level switch and remove that hose. Blow out the sediment in the base of the tub and reattach that hose securely. Then pump out the water in the tub so that the pressure can have a chance to build in that tubing. Retry and party on!
I have over 500 free service manuals at my appliance digest link HERE
Mar 26, 2011 | Washing Machines
On spin cycle water leaks from under the washer all over the floor
First thing is to make sure the washer is level and balanced, use the screws on the bottom and a level. Once level run and see if leaks. Also move closer if possible to the place the water drains to(or is supposed to drain to). If there is know leveling screws check manual to get part number to order, but first check other solutions as not to waste cash on screws you don't need.
Jan 31, 2010 | GE WBSR3140DW Top Load Washer
The water level does not stop where it is set-also as soon as you turn washer on the water start flowing in-Model-LXR9245EQ1-what part do I need thanks bill
Wow the water level switch could be bad or the hose going to it might be clogged. You need to know how to access this stuff. MANUAL
Aug 31, 2009 | Washing Machines
Water won't stop filling washing machine.
Hi, Will the water shut off if you turn the timer off or unplug the washer?
If it shuts off when power is turned off to the washer, you need to look into the water level switch. If turning off power to the washer will not stop the water, you need to change the inlet valve.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Washing Machines
TB3 Brewer is brewing weak tea - how do I adjust?
Hello. Yes, however, you would need to adjust the brewing cycle time to make up for the lost bypass water in order to get the same container level. In other words, the cold water part of the brew cycle is separate from the hot water part of the cycle, if you put in less cold water, and want to keep you container filling to its current level, you would need to increase the hot part of the brew cycle to make up for it, other wise it will brew less into your normal container. If you go to:
http://www.bunnomatic.com/
find your unit by model/type, you should be able to get a owners/installation manual, this will tell how to do it, or call the manufacture.
Hope that helps, and thank you.
Dec 22, 2008 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
Haier XQB40-F Top Load Washer Logo
27 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
