Question about Ovens
I do not what the power source is 3 pole 3 wire or 3 pole 4 wire
I am trying to buy a new oven, but I do not know what my current oven power source is. It was here when I bought the house 10 years ago and the manual does not say
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 112 Answers
If you look at the power cord (or where it plugs in) you will be able to note if it has 3 or 4 prongs (or slots to plug to). Easiest method is to simply take a photo of the plug or the socket and take with you to the appliance store (or where ever you are purchasing the new one from).
Posted on Nov 21, 2013
hotuna
  • 288 Answers
SOURCE: 3 wire oven with 2 wire source
Your new oven utilizes 220 volts, but it also has some 110 volt features that need a neutral to work properly. Your old oven was wired without the neutral, probably when the house was built. There are 2 answers to your question. #1, no you should have an isolated neutral or common (same thing) wire, so it should have one. #2, if you connect the white on the new oven to the ground wire it will work. The neutral wires are all connected to the grounds at the breaker panel. Look at it if you don't believe me. The ground is there as a safety to you. if you connect the neutral (the white wire on the new oven to ground) you will be eliminating the safety feature on that appliance. So, I do not recommend you connect the white wire on your new oven to the ground wire out of the wall. But if you do it will work, you will just not have any back up protection if there ever is a problem with the electrical on that appliance. I hope this wasn't too confusing, the answer is you will need to wire the oven properly by adding another wire if you want to be completely safe and within electrical codes.
Posted on Dec 06, 2007
  • 184 Answers
SOURCE: Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Posted on Apr 10, 2008
SOURCE: Kenmore Elect Built-IN Oven Model 790
OLD MODEL KENMORE STOVE.....THEOVEN DOOR IS LOCKED AND WILL NOT OPEN....NO F7 OR BEEPING SOLUTION....IT IS TO OLD...WE TRIED UNPLUGGING AND REPLUGGING. NADA!!!
Posted on Jun 23, 2008
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Posted on Dec 08, 2008
  • 81 Answers
SOURCE: Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Posted on Nov 17, 2009
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
What size circuit breaker for rbs305pr oven?
If you're connected to a 240V source, a two-pole 40 amp circuit is required. If connected to a 208V source, a two pole 30 amp circuit is required.
But the limiting factor here will be the wire size. If installed with #10 copper wire, 30 amp will be maximum. If a #8 copper (or #6 aluminum) 40 amp is maximum. See the link below for details.
http://www.whirlpool.com/digitalassets/GBS307PRB/Dimension%20Guide_EN.pdf
Sep 24, 2015 | Ovens
Simpson stove has 2 2PH, 1 N and 1 E poles, but power lines only 3 wires-1 red, 1 black and 1 green. How to connect the wires to stove.
I believe the proper sequence is red to ph1 black to ph 2 and green to N and ground. Newer ovens do require a 4 wire plug and this is th esetup for them
Apr 02, 2014 | Ovens
Model ww2460B double oven. need thermostat 71001138. can I get it anywhere?
Good luck with that!!! I had the same problem and scoured the internet for a solution. If you can find a used or rebuilt part you may be in luck. The thermostat on the left is a 6 pole one for the upper oven while the one on the right is a 4 pole for the lower oven 71001126. I doubt you can substitute the one for the other and give up the convection and self cleaning functions. Let us know if you find a solution or buy a new stove. Sears has a few 24 inch double ovens left, as the world is moving to 27 and 30 inch ovens.
Oct 27, 2011 | Jenn-Air Electric Double Oven
Hi, I am thinking about buying a logik lbfanx10 oven but I understand it has to be hard wired. My old oven is simply fitted with a 13amp plug and it just plugs into a socket. As I do not know the power...
The following website installation and user manual indicates a current value of 13-15 Amperes. You may have upgrade the wiring and the plug.
https://www.manualslib.com/manual/935752/Logik-Lbfanw10.html?page=11#manual Specification Model LBFANX10
Rated Voltage 230 - 240 V
Rated Frequency 50 Hz
Power 3200 - 3500 W
Current 13 - 15 A
Top Element 1200 W
Bottom Element 1100 W
Oct 10, 2017 | Ovens
I just bought a maytag 24 inch double oven.it is 240 volt and i need to know if i need to put a 3 wire or 4 wire for the power
Which plug you use depends more on the outlet in your house than the oven usually. If This is a new oven with digital controls, 4 is preferable (I've seen a digital dryer blow the boards because a 3-wire lost it's ground) but if the outlet is 3, you don't have much choice but to go with 3 unless you rewire the outlet back to the fuse/breaker box. As long as it's in good condition, 3 should work fine.
Feb 14, 2011 | Maytag Ovens
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
Stove working, broiler working, oven NOT working .. explain pls.
Assumption: This is an electric oven(?).
You seem to be saying that the bottom heating element in the oven is not coming on.
This can be caused by three possible failures: 1. Thermostat (this is the dial you turn to set the temperature); 2. Selector dial (this is the dial you turn to select the mode (broil, cook, etc); 3. the heating element has failed.
My guess is that the heating element has failed (usually the culprit). It is easy to remove.
1. Unplug all power.
2. Unscrew screws at back holding heating element in.
3. Pull heating element out (it may may electrical connection with a jack built into the wall of the oven cabinet or it may have wires you have to disconnect).
4. If you know how to use an ohmmeter, check the element for continuity. It should have some resistance but not MegaOhms.
5. If you don't know how to check, take it to the parts store and let the counter guy check it for you OR just buy a new one and try it out.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | GE Ovens
Electrical intallation
check the wattage from the rating plate and that will tell you
Sep 14, 2008 | AEG B5741-4 Electric Single Oven
Dec 06, 2007 | Frigidaire FEB24S2AB Single Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
