Question about Cell Phones
Motorola C401A battery warning
Tried to replace the old rechargeable batteries with freshly charged new rechargeable batteries, but the phone doesn't detect the new batteries. How come?
SOURCE: phone not charging
Unable to charge
Posted on Oct 12, 2008
SOURCE: Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Posted on Nov 22, 2008
  • 7 Answers
SOURCE: My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Posted on Mar 22, 2009
fwadley
  • 482 Answers
SOURCE: BATTERY UNABLE TO CHARGE
shorting out battery
Posted on Apr 17, 2009
GrinningFool
  • 625 Answers
SOURCE: BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
Posted on Jul 05, 2009
W180 charging
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 26, 2013 | Motorola Cell Phones
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 26, 2012 | Motorola Mobility RAZR V3
Why its battery quickly drains
Jul 18, 2011 | Motorola Mobility C168 Cellular Phone
My motorola defy shows a white light when i plug in the charger but the screen only says LoadBoot. 09.10 and Cannot program battery low.... doesnt the white light mean its charging? I've tried taking out...
If you bought it from a specific company be it thru internet or site store take it to the providers site store and if there is no water damage and item is less 1 year old factory warranty covers the phone and if you got an extended warranty they should replace it in the the store, but with factory warranty they will mail you a new one (with the exclusion of the battery) and you will have to return the old one thru the USPS at their charge.
Hope that was helpful if I can help further let me know. Please rate/vote or testify to my advice.
Wicked Angel
Nov 18, 2010 | Motorola Mobility Defy Cell Phone
My phones died so I charged it and when I try to turn it on it says m blur n the word blur flashes as usual but its been on that same screen for likr ten minutes what do I do?
Hi, well hopefully it will NOT be anything too serious. Now first remove the battery, wait a minute, and replace the battery. Now see if it "Boots up" OK, if NOT, then even though you recharged maybe the battery had a fault, you must in this case obtain a new freshly charged battery, and try that one
try a hard Reset, see below... This will erase all data BUT it may get your phone back.
http://cellphonerepairtutorials.blogspot.com/2010/05/motorola-cliq-xt-mb501-hard-reset.html
http://cellphonerepairtutorials.blogspot.com/2010/05/motorola-cliq-xt-mb501-hard-reset.html .
Aug 25, 2010 | Motorola Mobility CLIQ Cell Phone
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
Dead battery won't recharge
if it still new and you've still got the warranty then you should ask for replacement of the whole unit.
seems that the problem of your phone is the unit itself, the charging circuit migth have disorders/malfuntioning.
ever tried checking for the specifications and directions for charging the unit.
i greatly suggest that if you got the warranty still, have it replaced.
good day!!!
Feb 28, 2008 | Motorola Mobility RAZR V3
Battery Charging
If both the charger and the battery are warm to the touch, the battery is probably charged.
The low battery level warning level is learned by the phone. To train it, allow the battery to run down once until the phone stops working, then recharge it.
The best way totest the charging operation would be to try using the phone. Fully charged you should get about 6 hours of talk time from a fully charged battery, and at least a week of standby operation.
Dec 25, 2007 | Motorola Mobility V176 Cellular Phone
Cell Phones Logo
249 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
