Question about Royal Sovereign 12000 BTU Portable Air Conditioner
Power plug got submerged in water and hasn't had power since
    Sergeant:
    Champion:
  • 310 Answers
Check the breaker and the plug has a breaker to
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Nov 21, 2013
I have a 1966 Johnson 20 hp model fd-20c outboard motor. It has low power. The motor is mounted so low that the pee hole is submerged nunder water when running. Could this be the cause of my low power...
Try mounting it properly,cavitation plate 1/2 inch below bottom of boat.An old motor like that many things could cause a lack of power.
Sep 06, 2014 | Boating
I have a 2006 dodge dakota I submerged in water and blew motor. Since then I replaced motor and trany with 2010 3.7 same motor. Drove it long enough to blow holes in both valve covers to figure out cats...
The '06 computer won't know how to properly mix fuel for the '10 motor, lots of things are different between the two of them, and combustion will be different.
Have you gone through the transmission & axle(s) to get rid of the water that got into them when you submerged the truck?
BTW... a plugged catalytic won't blow any holes in the valve covers.
What do you have for OBDII codes from the computer?
Aug 01, 2014 | Cars & Trucks
Nisaan maxima submerged in water i already change the computer plate. still not strting
all the connectors have water in them take the plugs out of engine make sure no water in there and check the tranaxle for water
not a good situation going have all kinds problems
Nov 22, 2013 | Cars & Trucks
Power plug fell and got submerged in water, cannot get power to appliance ever since. I took plug apart and dried inside, but when i plug it into the plug -in there's no lights, power or anything at all....
does it have a ground protect circuit on? if it does you have to open and clean it with acetone and a tooth brush or replace the plug.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Nov 21, 2013 | Royal Sovereign Heating & Cooling
What's the difference between in-line and submerged water pumps?
There are many differences between the two of them in the way they run but the main difference is the in-line water pumps run outside of water and stay dry the whole process and submerged water pumps run underwater usually in the sump of your filter.
Aug 09, 2012 | Fish
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
How to fix a d.s whith water in it
not much you can do if it was on when submerged it most likly shorted a fuse or more
if it happen recently and was not powered up when submerge and not tried since (fix) best if taken apart but can do while together
submerge DS in destilled water ... I know sounds crazy but it doesnt have minerials that cause corroding on boards etc that tap and well water have ... let it completely dry for a few days it should power up and be fine.
Works with cell phones etc
Aug 03, 2010 | Nintendo DS Lite Console
Pump trips GFI when submerged
Check your power cable for any hole and damage, that might be the problem
if not
remove the 2 screw where the cable is connect on the pump, gently pull off the ruber from the cord and check if your 3 wire are wet ? and if any water can come out of the cable hole?
if yes you have to take most of the pump appart to make the stator and rotor get dry and also check for any black part on the stator, to make sure it not burn if you cant find any black spot on the part let it dry for a week and spray some air on the stator everyday and your problem will be fix,
At our big factory we use special oven to dry the part quicker
If you have no water that came out from the inside of the pump it has to be the power cable or your breaker the reason why the pump work fine when only the base is submerge is because the pump have less restriction (Water to push) so the engine work is very light compare when she is submerge and have to push so much water alll the way throught the hose.
I can help you if you need more info,
Aug 24, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Canon Powershot 870IS accidentally submerged in water.
when the camera falls in the water, only the power supply would have got bad, just take it to the manufacture, he will replace the power unit, it will work as good as the new one,, thank you,, plz rate me
Jun 30, 2009 | Canon PowerShot SD870 IS Digital Camera
Royal Sovereign 12000 BTU Portable Air Conditioner Logo
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
