Question about Cooper Wiring Devices Motion Sensing Switch- 30 Feet
How install a sensing switch WSP-250
How install it
    New Friend:
This sensor has 2 wires coming from it, a red one and a black one. You must connect the feed (hot) wire from house to black wire and the red goes to the light wire.
Posted on Nov 27, 2013
Can't get wi-fi to work
Your network is working for hard wired device, now you want to make it WiFi. Your router should have WSP button. Press and hold for a few seconds then release. See if your network is now visible on the device you want to connect. If so now type in network password.
Sep 29, 2016 | Computers & Internet
1989 dodge 250 the red ignition wire is getting hot and melting in two when the key is turned to the run position
Blue wire to ignition switch,from alternator voltage regulator.( 12 volts ) ECU power wire, Red wire to battery terminal. Blue wire goes from alternator to the ignition switch. The voltage regulator senses the incoming voltage from the blue wire. ) it grounds the green field wire This energizes the alternator field, and the alternator begins to produce a charge and sends it to the battery via the main output wire. When the voltage regulator senses 14 volts from the blue field wire, it cuts the ground to the green field wire. Good-Day!
Sep 21, 2014 | Cars & Trucks
How to install maystar s20/50
Maystar s20-50 connections.
Red + to permanent supply via 15A fuse
Black - vehicle body earth wire
Pink - negative trigger input, connect to additional earthing (pin) switches for bonnet boot etc.
Violet - for connection to negative switched courtesy light door switchs
Blue - ACC wire connect to an ignition switch positive supply
Yellow- connect one yellow wire to the left indicator and the other to the right inicator. Ensure that you connect to the switch output to the bulbs, not the supply to the switch.
White - Current sense loop- cut for current sense leave intact for non current sense.
Green - Antenna wire must not be cut or terminated.
Quick connect, for connection to additional Maystar control modules and sensor systems, follow the instructions supplied with the additional sensor.
Jan 16, 2013 | Cars & Trucks
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
Welder will weld for about 30 minutes and then will not weld until the unit cools down. generator function is normal. the repair shop told me that the welding leads were bad so I replaced them and have the...
If you check the wire A4 which connects the bridge to the current selector switch, make sure the connections are clean and tight. The sense wire parallels it and dirty connections on A4 can make more current flow through the sense wire than normal.
It is also possible the current sensor may be faulty, or has a bad connection, or is even seeing transient spikes from brush noise. The sensor connects to terminals 3 and 4 of J2 the 4 terminal connector on PCB1. And looks like a plastic and metal donut The sense loop for welding is supposed to be a single loop through and the generator sense should be 3 loops through.
Sep 12, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
How to install leviton 5225 wsp wall switch/receptacle with three wires wilsoncarey@att.net the old switch has a pilot light /switch /receptacle
For this combo , the white wires connect to the two silver screws on one side of the combo .The black power wire connects to the screw next to the switch. IF you want to have the receptacle hot all the time then jumper the hot black from the switch screw to the receptacle screw. The screw in the center is for the black wire from any lihghts that you want to control. IF it is the receptacle that you wish to control with this switch .. then the power connects to the screw next to the switch and the center screw jump a wire to the screw next to the receptacle
Jan 15, 2010 | Leviton 5225WSP Switch and Outlet
I am trying to set up a password for my belkin router when I go wireless
its the wireless that you need to secure. Open a browser and go to the router's IP (e.g. 192.168.1.1) If you dont know the IP, go to Start> Run . type"CMD" hit enter > type "ipconfig" hit enter, the router's IP will be Default Gateway: 192.168.X.X.
click on security in left column,
default login is blank, just hit submit
security mode= wpa-wsp (no server)
authentication= wpa-wsp wpa2-psk
encryption= tkip+aes
pre shared key = (create password)
click apply changes.
(only those who know key can use network)
Aug 11, 2008 | Belkin Computers & Internet
Cooper Wiring Devices Motion Sensing Switch- 30 Feet Logo
196 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
