Question about Porter Cable Garden
How do i load staples into porter cable stabler ns 100a
2 Suggested Answers
sflummox
  • 72 Answers
SOURCE: We purchased a Porter Cable
Porter-Cable/Delta has an excellent support site, where you can find pdf manuals, part numbers, etc.
http://servicenet.deltaportercable.com/
Porter-Cable DA250B is an angled finish nailer- it drives 15 gauge brad nails, and won't work with staples. There are some smaller pneumatic tools that can drive both brads or staples, they are typically the smaller 18 gauge fasteners.
If you have the correct 15 gauge angled nails, the DA250B manual has nice pictures showing how to insert them.
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DA250B
Posted on Jul 16, 2011
Ns 100a 1/4
What problem are you having? All you wrote was NS100A which is the model number of a Porter Cable 18 gauge, 1/4" crown stapler.
Feb 04, 2012 | Tools & Hardware - Others
We purchased a Porter Cable Staple Gun, Model # DA250B. Unfortunetly, it does not explain how to load the staples into the gun! Could you please help us. Thank you, ...
Jul 16, 2011 | Garden
I have a ns100a porter cable narrow crown stapler. The driver will not retract, so it will not shoot staples. what can be the problem and how can I fix it? Thanks Pam
Usually when the driver is slightly bent, it will not retract. Easy to check. Remove the head and pull out the cylinder and driver together. Adjust the driver or replace as needed.
Jun 04, 2011 | Porter Cable Cable 18 Ga 1" Narrow Crown...
We don't know how to put in new staples. We r fixing a chair
If your brad nailer is a BN200; I don't believe it will accommodate staples.
Feb 14, 2011 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I am thinking of getting a compressor for my husband for christmas...looking at Bostitch and Porter Cable..both 6 gal portable...cost is comparable, in stock at both Lowes and Home Depot. We are going to...
Eighter one of these will work good for nail guns personaly i have the porter cable and i like it i do a lot of construction work. And i think the porter cable comes a finish nail gun for small nails and staples mind did. But there not for running tools that require a large volume of air like air sanders air rachats or air cutters.
Dec 20, 2010 | Porter Cable C2002 150 Psi 6 Gal...
How to Load?
By looking at the picture it seems you have a framing nail gun, you can't load staples in it!!
Apr 22, 2010 | Porter Cable FR350A Factory Reconditioned...
Ring gone
go to dewalt service center for porter-cable parts. get a repair kit for the gun
Oct 10, 2009 | Porter Cable-Cable NS150B 1/2-inch to...
I have a Porter Cable narrow crown staple gun (NS 150A) that doesn't fire. When the trigger is pressed, it just pops a little, but won't fire. I've taken it apart an nothing is obviously broken....just...
Sounds like you have a broken head valve seal. It is located in the cylinder behind the head valve. You will have to get the head valve out. You can do this by hitting the head on a maleable surface like a 2x6 (so as not to damage the head) with the open side down. Not too hard but hard enough to dislodge the valve. Also check to see if the valve oring has been damaged. Sometimes the oring will get caught in between the housing and the valve and that will cause that popping sound with no action. Check your schematic for the tool and look at items 104, 106, 107, 108 for damage. One of these parts is the culprit if everything in the body below is ok as you say. Make sure the the driver is not sideways and damaged along with the cylinder while you are in the tool. Test to make sure the driver slides easily with some drag up and down. There could be one more culprit and that would be in the trigger assembly item 209. Check to make sure that all seals are accounted for and that none are damaged or blocking airflow. If you have any questions please post back.
Oct 06, 2009 | Porter Cable Tools & Hardware - Others
Garden Logo
27 people viewed this question
Top Porter Cable Garden Experts
Jim Goldsmith
Jim Goldsmith
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
