Question about John Deere Garden
John deere x340 transmission oil leaks
John deere x340 hydrostatic transmission oil leak
  • 246 Answers
SOURCE: john deere 2020 water pump repair?
Hello:
From your Description it Sounds like a Bad Water Pump Bearing and Seal.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 11, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Posted on Nov 14, 2009
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
What kind of oil is used in a sabre hydrostatic transmission
John Deere transmission fluid recommendations
For Sabre? and Scotts? garden tractors and commercial mowers
This bulletin serves to clarify the transmission fluid service requirements for several models of lawn and garden product and commercial mowing equipment that were recently introduced. The operator's manuals for these products call for 20W50 synthetic oil, which is not carried in the John Deere parts system.
The following chart has been developed from the factory and engineering as approved replacements for 20W50 in each application, and should supplement the information previously published. Transmission fluid recommendations Machine Model Recommended oil for service requirements Sabre
2048HV
2148HV
2254HV
2354HV
2554HV
Plus-50®, 0W-40
or -John Deere Hy-Gard®
(bothoils are for top-off only) Sabre All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Scotts S2554 Plus-50®, 0W-40 Synthetic
- or -John Deere Hy-Gard®
(both oils are for top-off only) Scotts All other models Turf-Gard? 10W30
- or -
Torq-Gard Supreme?, 5W30 Mid-Ztrak
Mini-Z M653 through M665
737/757
717/727 Plus-50® II, 15W-40
Plus-50®, 0W-40 Synthetic Front-Ztrak F620
F680/F687 Plus-4?, 10W40
- or -
Plus-50® II, 15W-40 QuikTraks 647/657/667 Plus-50®, 0W-40 Synthetic Last modified: 23Jan10.
Apr 03, 2017 | Garden
John Deere 430 lawn tractor hydrostatic transmission will not work in forward or reverse even with no weight on the axle. New filter and oil did not fix. What should I check next?
Some have a procedure for "burping" air from the hydraulic system. Changing engine oil and filter won't affect it- independent system.
Apr 02, 2017 | John Deere Garden
Oil leak center case to left of oil filter gasket leaks bad after shut off is there a check valve inside
I would replace the filter. turn filter on BY HAND til the gasket seats, then 1/4 turn more ONLY (light film of new oil on gasket, dip fingertip in oil bottle and wipe onto gasket)
Oct 15, 2016 | John Deere Riding Lawn Mower. D170 54 in....
My John Deere rinding lawn mower won't go forword or backwards
John Deere mowers, for the most part, use hydrostatic transmissions. These use an oil of some type (they vary by model) in the transaxle to provide hydraulic pressure to move the tractor. Older tractors will eventually experience some oil leakage over time due to seal wear. If the level gets too low, then you fail to move. Check the oil level in the transaxle. The location of the reservoir varies from model to model. If it is low, after determining the correct oil to use, fill to proper level. Then, start the tractor and work the hydrostatic drive lever forward and backward slowly and continuously until you get full speed operations in both forward and reverse. This can take a few minutes until all the air has been purged from the system.
Oct 03, 2016 | John Deere Garden
John deere lx188
a lot of hydrostatic problems can be fixed by changing the oil and filter so try that first see if it helps
Mar 01, 2014 | John Deere Garden
I have a John Deere X304 with 4 wheel steering. I noticed what appears to be some kind of oil dripping from underneath the left rear axle area. HOW do you get to where you can check transmission and or...
X300, X304, X320, X324 and X340: The transmission is a sealed component. No maintenance is required on this transmission. If you suspect any transmission problems, please contact your authorized dealer. The transmission, power steering and hydraulics (if any) are all on one system, you won't be able to service it without disassembling it.. But it might be a bad seal. Try tracing it back to where it's coming from.
Oct 28, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LT155 oil leak
gasket or seals
May 05, 2012 | Garden
I have a john deere 316, the other day i was moving snow with it and all of the sudden it lost all power to the hydrostatic and to the front end quick attach. I was wonder what would cause this and how to...
First check level of hydraulic oil. Sight plastic tube just above and to the right of the hitch. Should be in the middle of the tube.
How long since you changed the hydrostatic oil filter under the seat deck?
Next see if the small splined shaft is turning btween the seat deck and the transaxle from the rear of the tractor. If not, it sheered a key in the hydrostatic drive shaft from the motor to the drive. (Had this happen to me)
Check the lever under the right side fender that disables the hydrostatic transmission to allow the tractor to to be moved without dragging the wheels. Make sure its not in the wrong position.
If all these are ok then the hydrostatic pump has failed.
Jan 01, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
79 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
