Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher and Paykel Dishwasher beeps while it washes dishes. Any solution?
Top drawer beeps the entire time the dishes are washing. Any fix?
  • 24 Answers
Here is a suggestion: I had problems with the top drawer on a model 603I, I found that the control board under the drawer cover (at the upper right corner) had a broken latch. This allowed the control board assembly to drop down at the right side which caused the electronic eyes at the side of the drawer to become misaligned. This was giving false information to the control board indicating that the drawer wasn't closed properly. My problem was fixed by securing the control board back in place making sure the electronic eyes were lined up properly. (Note: The electronic eyes I am referring to include two clear plastic tubes about an inch and a half long to the right of the control board. These tubes must be properly lined up with the led and photocell on the side of the control board) It sounds complicated but if you take the drawer cover off you will notice the control board alignment immediately. Its an easy fix if this is your problem. One way to fix it is to take a piece of string and tie the board back in place. (That's what I fixed mine with and it has worked like new ever since.) NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU BEGIN THIS REPAIR!
Posted on Nov 22, 2013
stephanos18
  • 144 Answers
SOURCE: DD603SS DISHWASHER PROBLEM
This is simple you need a new Detergent dispenser fitted in the bottom drawer. cheers
Posted on Mar 26, 2009
  • 15 Answers
SOURCE: The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Posted on Apr 30, 2009
  • 205 Answers
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
Posted on Jul 21, 2009
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel DD24DCTB6 top drawer beeps instead of starting
It is very likely the two problems are not linked. Use small quantities of power detergent (Finish works best) to avoid foaming. The foaming usually triggers flood switch and shuts dishwasher. If the beeping is constant then most likely the flood switch is triggered. But if you get one or 2 beeps when you press start, then it is likely some sensor in drawer is faulty. Usually the drawer close switch is not working.
Mar 18, 2013 | Fisher and Paykel Dishwashers
Control panel or electrical panel not working right. It stops washing at 10 minutes
The DD603 dishwasher from Fisher and Paykel is a very sofisticated electronically controlled dishwasher. It does not have a control panel or electrical panel unlike some of the other brands of dishwasher which are electromechanical controlled.
So if it is stopping with 10 minutes left on the LCD display, then it might have simply gone into the Dry mode. A small fan in the door unit starts up and sends warm air into the unit. At this time the dishwasher gives a couple of beeps. You will have to wait until the time display goes to 00 provided the dishwahser is set to be in the Clean Dish indicator option is on. This means the washing is complete. Refer your instruction manual.
It is also a good practice to keep the area around thw wash program button (on the drawer door top edge) clean. Sometime grime can cause false trips.
Hope things are not as bad as it may appear.
Nov 15, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Mar 12, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer has no electrical power
I f lock is activated during wash the draw will appear dead when wash cycle finishes ,check for lock symbol in lcd display if it is visible press lock button for about 5 seconds until you hear beep release button and try POWER button
Aug 23, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
Floods top drawer when washing bottom
The machine is not installed correctly, as it probably has a single air gap and the hoses for the two drawers are sharing that single air gap. These are basically two seperate dishwashers. There is a fix from fisher paykel parts:
http://www.fisherpaykelparts.net/index.php?categoryid=113&productid=7
Aug 12, 2007 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
51 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
