Question about Honeywell 7 Day Programmable Thermostat RTH7600D1006-E
Heat comes on and goes right back off
Heat runs for about 30 seconds and shuts off
2 Suggested Answers
SOURCE: My Honeywell Water Heater Thermostat
Time to call qualified service technician. And watch what that person does to learn about your water heater.
I assume you have Honeywell Icon gas valve. Honeywell makes different several model numbers.
Here is 'typical' Honeywell Icon gas valve service manual for Bradford White, that may or may not apply to your water heater. It shows testing for Icon and disassembly instructions, and error codes.
http://waterheatertimer.org/pdf/Bradford-white-service-manual-44943-D.pdf
Gas water heaters today require yearly service that includes cleaning burner parts and combustion chamber, checking vent and air intake, electrical connections, testing gas valve, checking gas pressure, bleeding air out of gas line, etc. These are things you can learn to do by reading service manual, and making sure you have a spare water heater around to connect real quick if experiment goes wrong.
If Icon gas valve is problem, that control is modular and can be replaced without draining tank.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Posted on Aug 08, 2011
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
My heater isn't blowing any heat. I hear the fan come in, and i think i hear the gas come on, but nothing comes out of the vents. The fan only comes on for a couple of minutes and then goes off.
Ok so here is a sequence of the heater lighting and the solution for your problem...
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning. Please see the pictures below to help you identify a flame sensor.
Thanks and I hope this helps. Feedback apprec.
Jan 28, 2011 | Honeywell Electronic Programmable...
I have a ng furnace downstairs that started this a couple of days aga....It comes on like it is suppose to and runs until it shuts off. Once the blower cuts off it stays off for about 1 second and then...
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 06, 2010 | Heating & Cooling
Hello, The problem is the ignitor comes on for a few seconds then goes out. The fan keeps running but no heat is coming out. Any suggestions? The model we have is Amana air command 90. Thanks.
Nov 28, 2010 | Heating & Cooling
My gas burner comes on and goes for about 30 seconds to a minute and then shuts off and then 30 seconds or so later will come back on
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 24, 2010 | Magic Chef CYG2000AWW Gas Dryer
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
OUT SIDE UNIT SHUT DOWN IN HEAT MODE, WHEN YOU FIRST TURN IT ON IT RUNNS FOR ABOUT 30 SECONDS THEN BOTH THE COMPRESSOR AND FAN SHUT OFF FOR APROX 3 MINUTES {LARGE LINE STARTS TO GET WARM} AFTER 3 MINUTES...
Hi, You have a heat-pump, this I do no. The reason it is shutting down from how you have explained it to me, is the compressor is shutting down due to high pressure and it is going off on the internal overload. When the compressor cools down, it starts back up and runs again. As for the large line getting warm, this is normal for a heat-pump as in the summer this line will be cold. The reversing valve changes over the flow of freon and the flow goes in the other direction. Back to you're problem. The service tech is bleeding off freon because he is apparently showing with his gauges it is over charged? This will cause it to draw to many amps and shut off. Has this compressor been changed out recently? Or maybe freon added due to a leak? He is doing it because he is thinking it is over charged. It may be some if it runs for a few hours after it is bled off. Did you notice if he clamped his meter around a compressor wire to check the running load amps? If so, that's what he is doing. I would say this unit had work done on it recently or correct me if I am wrong. The condenser fan motor should not shut off with the compressor, it should run all the time even if compressor shuts off on internal overload, believe me!! The fan is wired separate from compressor. The only time this fan shuts off when heat is on, is when it goes into defrost, and compressor keeps running. For the compressor to run for only 30 seconds and shut off, and then back on in 3 min, on for 5 seconds and off again, sounds to me this unit is short cycling due to being under charged. It is strange it runs after he bleeds freon off for a 1/2 a day. As far as the fan shutting down to, and I would like you to get back to me, if the compressor was changed at some point, the fan wiring was connected to the contactor load side, so it shuts down when compressor shuts down. One fan lead is on the wrong terminal of the contactor. If this is the original compressor, this could have happened at the factory, I have seen this before. The tech should have seen this!! Going on and off this fast, would not cause the compressor to get hot enough to kick off and cool fast enough to come back on that fast! Sounds like low pressure. I don't like to knock other techs work, but this unit is not being checked properly. Without me being there to install my gauges and amprobe, all I can do is tell you he is wrong with his solution, way off. Heat-Pumps are much more tempermental then a split a/c only.What to do is call them back out and request a different service tech, or the service manager. This will be no charge to you! You should be reimbursed for the last call. E.P.A. allows us to only loose minimus amounts of freon installing our gauges also. It is forbidden to bleed it into the air. He could be fined $25,000 the 1st time!! It also sounds as though you have a problem in the defrost board that would cause this. Please call them back out and don't feel bad about it. This is you're right! Tell them about the fan also as if it is going off on high pressure which I think not, the fan would stay on. I know this is long but I want you to understand what is going on. I do this for a living and know whats up! I am a Licensed contractor in this field. Please keep me posted. I will be waiting to hear back.
Sincerely,
Shastalaker7
Dec 21, 2009 | Heating & Cooling
I have a Hitachi PJTX100.....been using it for a year and a half and it has been flawless.....until recently....After about 30 minutes of use it shuts off....meaning the screen goes black and the actual...
i believe your problem is heat the bulb is getting hot and the air or fan is not working properly so when it hits temp it automatically shuts off check your fan air flow filters etc
Jan 10, 2009 | Hitachi PJTX100 Multimedia Projector
Roper Dryer not Drying
Get a thermostat and place it in the exhaust. The thermostat should reach 160 and then shut down and drop to 120 F and start back heating to 160 again on cotton setting. You should hear an audible click when the thermostat opens and closes. If the dryer is clear of lint and blockages then change the control thermostat which is mounted on the blower housing.
Sep 07, 2008 | Roper REX3614KW Electric Dryer
Honeywell 7 Day Programmable Thermostat RTH7600D1006-E Logo
27 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
