Question about Coleman York Hamilton Furnace Control Circuit Board 031-01267-001 031-01267-001a
7 flash code
Heater is not igniting
Troubleshooting blink codes
There is actually a legend on the ignition control module that you see flashing. This is a very basic troubleshooting code, usually it blinks 3 times, meaning ignition lockout (heater tried to fire unsuccessfully 3 times)
Jul 16, 2014 | Lochinvar ENERGYRITE 150K BTU NATURAL GAS...
Pentair heater will not light
This could be a temperature sensor issue, however you should open the panel and look at the ignition control module, there is a red light that will flash and based on the number of flashes it may tell you more information. Open the panel the. Try to fire the heater and watch the light and see which flashing sequence it gives you, post back with that information and we may be able to figure it out
Dec 06, 2013 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Rheem/Ecosense, ECO-180DVP, tankless water heater,flashing code 11
Unknown if this is new installation.
New installation, you may need more gas to the unit.
Call the propane dealer.
The dip switches for selecting LP or NG may be set incorrectly.
If this installation worked before and stopped working:
Before calling service technician, copy following link for troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code 11 is ignition failure.
Keeping up with regular maintenance can eliminate a lot of common error codes, but the cost is greater than expected savings from owning a tankless.
Regular maintenance such as cleaning combustion parts, checking gas pressure, testing solenoid gas valve, sanding carbon off the igniter, checking igniter wiring harness, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 21, 2012 | Water Heaters
I have modle #DGATO75BDF and it is blinking 1 time im thank it is the igniter
I think the flash code is for flame with the gas off not a hundred percent sure but this furnace has a recall.
Oct 09, 2010 | Coleman Propane Forced Air Heater...
I have a Nortitz natural gas water heater, model #N-063s-1. Acouple of days ago it stopped heating the water. what can I do myself to fix this matter. Thanks, lynnatheana@hotmail.com
There are many reasons a tankless heater will stop heating water. The first thing I would look for is a flashing red light on the burner indicator. The flash break down goes as follows
continuous blinking - typically means ignition failure or the unit is overheating; look for visible water inside the unit, have your gas pressure checked, or check the flame rod/igniter for buildup of debris
three blinks - typically indicates 16 error code; typically resolved by performing a descale
4 or 5 blinks - exotic error codes; for these you should definitely contact Noritz tech support
If there is no flashing light, first check your filter for debris. If the filter is clean, your flow sensor is probably stuck. Again I'd recommend contacting Noritz tech support to help you clean the flow sensor.
Jul 31, 2010 | Noritz 6.3 Gallon Residential Tankless...
Sometimes the hot water just goes cold
Here are a couple things to look for:
1) flashing burner light - a flashing burner light indicates the unit is getting an error code
common error codes:
A. continuous flashing - ignition failure or abnormal combustion; look for visible water in the machine indicating a leak, check gas pressure, debris or buildup on flame rod/igniter plug, or clean unit with compressed air
B. 3 flashes - error 16, abnormal outlet water temperature; typically this code indicates you'll need to descale you unit
C. 4 or 5 flashes - exotic error codes; you should contact Noritz technical support to deal with these codes
2. If there is no flashing code, try increasing the hot water flow. In the summer time you typically use less hot water; this can result in intermittent operation of your tankless heater. Increase water flow by either: A. cleaning your showerhead and removing scale deposits B. widening your flow restrictor C. Remove your flow restrictor in the showerhead
3.If none of these resolves your problem, you probably have debris in your flow sensor. Contact Noritz technical support for a walkthrough on removing debris from a flow sensor.
Feb 18, 2010 | Noritz 6.3 Gallon Residential Tankless...
Thermostat call for heat but the heater doesn't ignite
what number of flashes does the led light on the circuit board show for an error code?
Nov 25, 2009 | Mr. Heater Natural Gas Garage Heater -...
Not igniting
There can be several reasons your not igniting. You may have a dirty filter, safety switch engaged etc. There is a diagnostic light in the bottom compartment that flashes a code. see what code it is flashing and post that info. The breakdown for the code is on the back of your door.
Mar 29, 2008 | Goodman GMS90703BXA Heater
Coleman York Hamilton Furnace Control Circuit Board 031-01267-001 031-01267-001a Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
