Question about Sony Nsgmr1 Remote Control
How to open back to get at batteries - Sony Nsgmr1 Remote Control
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
Hi ,i have s type jaguar. my battery gone flat and i cannot openthe booth at the back ,manualy or by electric. how to open the booth please ..help?
You can use one of the plugs that go into the power point/cigarette lighter. Cut the end off add wire to reach a good 12 volt battery. Plug it in. This should give you power to open the boot with the switch.
Aug 07, 2016 | 2002 Jaguar S-Type
How to put battery in coolpad
most battery covers are a push down and back to open them
so put your thumb on the small indentation / bars , gently press down and back and the cover slides back and off
Dec 06, 2015 | Cell Phones
New battery for Kindle Fire?
Step 1 - Back Case
  • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
  • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
  • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Step 2
  • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
Step 3 - Battery
  • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
  • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  • step 4
  • Repeat the process from the previous step to free the left battery cell.
Step 5
  • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
  • Pull the battery out of the Kindle Fire.
Kindle Fire Battery Replacement
Oct 31, 2015 | Amazon Kindle Fire HD 7in, 32GB
Replacing battery
Need a screwdriver. Unscrew the back of the mouse. Usually there's a compartment where the battery is isolated.
Apr 02, 2014 | HP DC172B Mouse
We need to chage the battery in our 2006 corvette key fob. How do you open it?
There should be a slot on one end that you can put a penny into or something similar, and it should pop open.
Jan 21, 2011 | 2006 Chevrolet Corvette
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Battery....can I get a battery replacement anywhere?
Most Skagen watches have a snap-in, snap-out back. You will need a tool to open the back such as a slotted jeweler's screwdriver or knife blade to pry it open. Be careful opening the back as the battery may pop out. Examine and make note of which side of the battery is up. Get the number off the battery, or take the battery with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. You may even consider taking the watch with you to the above retailers...some of them are willing and able to change the battery for you.
Dec 08, 2008 | Skagen Watches
Sansa E250 Battery Low always when charged fully
is it connected properly?there should be a green line going back & forth on a "battery" if the battery is no good,theyre cheap on Ebay.Make sure its new,check shipping costs as they vary.Open up the back-4 screws.Lift out battery.FULLY recharge.Very easy.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
Sony Nsgmr1 Remote Control Logo
41 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
