I am looking for a program powerchute personal for es 350
    Scholar:
    New Friend:
  • 129 Answers
Http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BK350&total_watts=200&tab=software
First download option should be the software you are looking for - if that doesn't work reply with the exact model number of the UPS.
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Posted on Nov 21, 2013
2007 420 Rancher ES. Why is it stuck in 3rd gear and seems to be flashing a code of 12?
Most transmissions go into a fail safe mode to prevent damage to transmission but you can still damage it if you keep driving it. Most related codes are due to speed sensors. But you will have to look up what the code means exactly.
Oct 08, 2015 | Honda Cars & Trucks
How to monitor Matrix 5000 UPS via email?
Try using use the agent and server of the Powerchute plus and the console of powerchute business edition run from another PC.
You may need version 9 or later of PBE.
Jul 29, 2014 | APC Matrix-UPS 5000 UPS System
HOW DO I KEEP MY MINUTE MAN BACKUP TO STOP BEEPING?
If you connect it up to a Windows computer with the supplied (goofy-looking) USB cable and install the APC Monitor progam "Powerchute" available on the APC web site, you can set all the activity levels and tell it just when to beep the beeper, or turn it off completely. I have two of these in my house, and have set them to never beep. The cable is goofy because it is USB on one end and a network-type on the other end.
Software Firmware
Jun 28, 2014 | APC Back-UPS ES 350 - UPS ( external ) -...
I need a program for my computer run a ups es 350
Powerchute personal edition is available for free download from APC. Does your ups have a USB port? The software is useless without it.
Nov 21, 2013 | APC Computers & Internet
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
APC 1100CI-IN UPS NOT EORING ON GENERETOR WHAT I DO? PLZ SEND SULATION E-MAIL singhpintu987@gmail.com
Hello Sing,
There is a possibility that your UPS doesn't like the voltage or frequency that the generator is feeding it. As per an APC knowledgebase article, the size of a generator should be 3 to 5 times higher that the total Watt/VA load that it would be supporting.
There are also instances wherein the sensitivity threshold of an APC BackUPS is set too high that a slight change in voltage/sensitivity would cause the unit to switch from online to on battery too frequently. This can be addressed by lowering the sensitivity either by their APC PowerChute Personal Edition Software or via the front panel switch.
If you are going to do it via the software, it needs to be installed on your computer. Prior to downloading it, make sure that your operating system is compatible with it. Suppose that your operating system is compatible, once the program is installed you will need to open it up and look for the Sensitivity option and from there you could select Low, Medium or High.
If you are going to do it via the front panel switch/button the UPS should then be turned off but plugged in to an input source. Press and hold the On button until you see that the LEDs are flashing. Once the LED is flashing, press the button again to set the desired sensitivity. Low sensitivity would show the On Battery LED flashing. Medium is On Battery and Overload LED while High is On Battery, Overload and Replace Battery LED flashing. If you'll see a flashing Online LED it means that you are cancelling or exiting the program mode of the UPS.
Below are some helpful links from APC
*** You will need to login in APC before you can download the software. Choose the correct PowerChute Personal Edition Compatible with your OS and create an account online.
Jul 22, 2011 | APC Back-UPS CS 500VA UPS System
Cannot open 2007 es 350 trunk
REMOVE TRUNK SWITCH INSIDE CAR,JUMP WITH PAPER CLIP AND CHANGE SWITCH,IF THATS NOT IT,PROBABLY COMPUTER KEY NEEDS TO BE PROGRAMMED AT DEALER.
Jun 01, 2011 | 2007 Lexus ES 350
Blown fuse 2007 lexus es 350
LOOK FOR THE FUSE BOX IT WILL SAY [ CL ]for CIG LIGHTER FUSE MITE BE A 30 JUST LOOK FOR THE FUSE BOX OR SEE LEXUS DEALER IT AN 2007 MAYBE 35DOLLARS OR LOOK YOURSELF
Feb 26, 2009 | 2007 Lexus ES 350
APC Back UPS 350 ES won't run on battery power.
>> I'm having the same problem with mine. I get 122 volts when plugged into the wall, and it tells me that I get less than 1 min of use once I unplug, and it actually lasts for 10 seconds before getting a screeching sound.
The screeching sound is normal. Its telling you "HEY, I HAVE NO POWER. THIS IS A PROBLEM." and trying to attract as much attention as possible. It will also do that if you run a self test with the software and the test fails.
Its been a while since I worked on these during an outage, but I believe there is a way to use the software (PowerChute business edition, if you're using a SmartUPS. There is a personal version with less features for other home models) to silence the alarm. I think some of them had a button you could push on the unit to silence it as well, but look this up first. Push the wrong one and it powers everything down.
Feb 17, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Transmission flare
I'm thinking of buying a 2008 ES 350 and have read the transmission flare discussions on different websites. I wouldn't want to venture a guess as to what the chance is of getting a new ES 350 with a flare problem: 0.1%, 1%, 10%, 50%? If the ES 350 has a flare problem, what is the chance of it being a severe problem vs. a minor nuisance: 0.01%, 1%, 10%, 90%? I've read about other problems afflicting the ES 350 such as engine knocks, interior rattling noises, and wind noise. I'm sure the ES 350 has some minor problems too but those are the major ones I can recall. The easy answer for the potential buyer is to cross off Lexus from the list. Why take the chance? The ES 350 was easily my #1 choice in terms of features and value. I was attracted to the Lexus brand because my impression was that Toyota and Honda generally make the highest-quality under-$40K cars in the world. What would make more sense than buying from Toyota's "luxury" division? Car magazine journalists regularly write about "legendary Lexus quality." That leads to a contradiction: Why does Toyota have such a stellar quality reputation even though it has had ongoing FWD transaxle problems since 1999? Why can't Toyota figure this out? Shouldn't Toyota thoroughly test pre-production models instead of making its customers responsible for quality assurance? Replaced transmissions, buybacks, amazing. It's hard to figure out the precise truth and a manufacturer is probably going to avoid transparency in this kind of situation, so I think I should move on to other makes and models. Any suggestions for FWD alternatives to the 2008 ES 350?
May 14, 2008 | 2007 Lexus ES 350
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
