My X9i seems to power up normally, and it works perfectly on programed workouts from the Android computer. In manual mode, it will only run the belt at 1 mph and it will not respond to manual control inputs (i.e.,it will not speed up or slow down, and the incline will not change). All the manual console buttons "beep" when you touch them, and, if you are running a workout program from the computer, if you touch ANY one of the console's manual buttons, the button "beeps" and the programmed workout is interrupted, but the machine does not otherwise respond to the manual input (when the programmed workout is interrupted, neither the belt speed or incline can be adjusted with the manual control buttons). I have checked the reed switch adjustment, and the motor controller's LED flashes when the programmed workout is running.
You need to replace the key pad
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
