Question about Marantz SR-7200 Receiver
Is it worth fixing a marantz sr5002?
Is it worth repairing the red blinking light issue or just buy a new receiver for less money?
    Genius:
  • Marantz Master
  • 1,054 Answers
If it's a blown amp channel, might cost around $150 to repair
Posted on Nov 21, 2013
smarthome2
  • 1114 Answers
SOURCE: marantz SR8001fail to standby mode, will not reset
Test all your speaker impedances and check for shorts on both wiring and speakers. Use a digital multimeter. If you still have an issue, disconnect all speakers and test receiver. If you still have a problem, post a comment and I can help some more.
Posted on Aug 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: center channel dosen't work on 10 yr old marantz
I'd do some more investigation first. Have you determined if the amplifier for the channel works or if it's a preamp problem using the built-in speaker setup controls?
With this unit's great audio processing features you might be able to bypass a failed amplifier using the pre-outs and drive an external amp for the missing channel.
You could always just get a modest stereo amp (like a Carver M-100T and bridge it), or use the extra channel for another center speaker or a subwoofer, for example.
Posted on Aug 12, 2010
SOURCE: Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Posted on Nov 04, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do I connect my laptop to my Marantz SR5002
Typically, your laptop would have a headphone output if you want to SEND audio to the receiver.
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the source player volume up.
You may have to find the sound controls on the laptop to raise the volume high enough for the reciver to use.
Posted on Feb 07, 2011
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Posted on Apr 06, 2012
Wegatv KP-46WT520 7 RED BLIMLS
This is a bad high voltage power supply. The blinks mean your horizontal deflection circuit has failed. This is not a user repairable item. It requires a service call from a tech. My personal recommendation is to not repair the TV as a 46" CRT RPTV is not worth putting money into. you can buy a new flat TV for less than the repair costs most of the time. However it is still worth talking to a local repair shop. IF they can fix it for less than $200 it would be worth it.
Apr 02, 2015 | Televison & Video
The red light on my Marantz SR5008 keeps flashing and wont turn on. How can I fix this
Disconnect everything and then plug in only the power. If the light still blinks, the PS is probably damaged and will need to be serviced. If the light doesn't blink, you have a shorted connection. Speaker wires are probably the most likely.
Oct 07, 2014 | Marantz SR5001
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
Marantz pm 6004 blikining red power standby
Are the speakers connected?
If so , you have an output DC voltage issue ( typically outputs dont want to see more than 100mV DC going to the speakers. If that happens , the Protect circuit will kick in. Find a repair tech in your area because I think this amp is worth fixing
May 21, 2014 | Marantz Audio Players & Recorders
How do I connect my laptop to my Marantz SR5002 receiver
Feb 07, 2011 | Marantz SR5002 7.1 Channels Receiver
We have a panasonic tv, model pt-60lc13, bought new in 2003. we use it less than 1 hr per day (last year we watched 2 movies). today, I turned the tv on, the green power light would blink slowly for...
This sounds like a power supply problem, or a vertical issue. The Panasonic sets are one of the best tv's out there and generally worth fixing, but it will need a tv technician to resolve the issues.
Jan 16, 2011 | Panasonic Televison & Video
SR5004 amp on standby mode (red light blinking twice a second) / cant get it out of stand by mode
I am having the same issue as well. If you press "clear" "exit" and "surround mode" all at the same time, it will come back on. It seems to be an overheating issue. If you put a fan on it, it helps, but does not fix permanently. Anyone have any ideas for a permanent fix?
Sep 20, 2010 | Marantz SR5001
Marantz SR8001fail to standby mode, will not reset
Aug 07, 2009 | Marantz SR8001
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Marantz SR 5002 Won't power on
I've just been told by my AV person that is a known flaw in the SR5002 that the power supply runs hot, blows out, and sometimes takes out other components by cooking them. Thanks Marantz. How about a recall?
Jun 08, 2008 | Marantz SR-5000
Marantz SR-7200 Receiver Logo
169 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
