Question about Western Digital WD Elements 1 TB USB 2.0 Desktop External Hard Dri
Data error cyclic redundancy check after pc it was connected to, went into "sleep mode". Doesn't work on any other PCs. Same error. Can this be fixed without formatting?
Had backed up a n umber of files, onto my WD External Elements 1.5 tb drive, yesterday. Was able to restore files from it. Had left it plugged into my PC, and the PC went into sleep mode. Ever since then, it has not loaded properly, and is giving a Cyclic Redundancy Check error, and states that it "Requires to format before use". Did I lose the drive/data? aor can it be fixed by a scan disk, or something?
    Sergeant:
  • 284 Answers
No you do not need to format it,
if the drive was assign a letter D: for example . type start... run...
chkdsk d: /f
Tony
Posted on Nov 21, 2013
3 Suggested Answers
LogicX
  • 93 Answers
SOURCE: my wd essential external hard disk is becoming
Try using a different USB port and change your cable.
Posted on Mar 13, 2011
bronk50
  • 27725 Answers
SOURCE: i can't access wd 320gb element external hard drive
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
even if you dont have any red or yellow marks you might have to
Click Start, then type device manager in the Search box then click Device Manager
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete restart your computer. Your USB controllers will automatically install
This method prevents your USB external drive from powering down
Disable USB selective suspend setting.
This method prevents your USB external drive from powering down.
Click the Start button type power plan in the Search box then click Choose a power plan.
Next to your currently selected plan click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings then expand USB selective suspend settings.
Click Plugged in then click the drop down menu and select disabled.
If youre using a laptop click Battery then click the drop down menu and select disabled.
Click Apply then click OK.
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on Jun 28, 2012
This is some serious problem when u get it on HDD......is the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
Tip
The NASTY "CRC" Error ......Tackle IT
What does CRC(Cyclic Redundancy Check “error”) mean?
There are plenty of technical resources on the Web that discuss cyclic redundancy checks (CRCs). Most times you won't need to worry about this technobabble. That is, until one it day it suddenly appears and you think - what the hell does that mean? In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear.
The most common time you will see the cyclic redundancy check error message is when trying to read data from a damaged CD or DVD. Just before it appears, your CD/DVD drive will probably grind and whirl away - your PC may also become a little slugglish.
Less frequent causes are the result of system crashes, and buggy software (hello Microsoft), incomplete downloads (often identified by the misleading message 'This is not a valid Windows file', 'This is not a valid win32 application' or 'Corrupt Zip file'). If this problem happens frequently with downloads, try using a download manager.
For CDs and DVDs, the problem is a little different. Normally, when CD/DVD drives get a CRC message from a disc, they try to read the disc again - hence the grinding sound. After several failed attempts, they give up and display the redundancy check error. The problem can be hardware (loose cables, failing drive), software or damaged media. In most cases checking and cleaning the disc is the easiest way to overcome the problem. If different clean discs produce the same error, it is likely to be a hardware issue (check the discs in another drive). Another common cause of these errors is poorly burnt CDs and DVDs - especially those that had numerous or severe buffer underuns. USB burners suffer from this problem when the burn speed is too high (generally above 4X-8X)
If the discs are damaged, you'll probably need a recovery tool to get back your data. CDCheck 3 will work for CDs and DVDs. First it will check the media, and then you have the option to recover the files. It's free for personal use and has saved many people heartache when it comes to recovering lost digital images and videos from damaged CDs.
on Dec 22, 2009 | Computers & Internet
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
500 MB data error(cyclic redundancy check) external hard drive is not accessible
1. this ( cyclic redundancy check) is the computers way of saying " i don't recognize the data check-sum.
2. This issue could be due to the data controller on the USB drive being defective.
3. try purchasing a new case with a new controller board.
4. Check to see if your 1TB USB drive is compatible with your pc.
Jun 13, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
We have been given the PC game V8 Challenge, but am unable to install the game. It installs to 88% then says: "Data Error (cyclic redundancy check)". Please can you advise as to how we get thte...
a Data Error (cyclic redundancy check), is usually a problem with the CD, is the CD dirty? you might try cleaning it, (you can pick up a CD cleaning kit at Walmart for $5). Or you might have a problem with your CD drive
Jan 04, 2011 | Computers & Internet
When i install,bluetooth setup in my desktop that time a information came like cyclic redundancy check problem.
Cyclic Redundancy Error comes when the source device like a computer calculates data and add the size of the information and sends it to the destination device. The destination device sees the size of the information and recalculate the size of the information and compare the two if they do not match the cyclic redundancy problem is reported because the information data has gone corrupt during the transit from the source to destination device. It can be a wrong configuration or packet collision. If it is due to packet collision the error can be over come by resending data multiple times.
Sep 11, 2010 | Computers & Internet
Data error cyclic redundancy check. I have windows XP.How do I fix this?
Your disc is scratched. That error will come up when it happens. Try to clean your disc. get all the fingerprints off of it.
May 24, 2009 | E-Machines eMachines Desktop PC
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Thanks
Mar 01, 2009 | Computers & Internet
Samsung D900 cyclic redundancy check error
PC Studio 3.1 is the recommended software for Samsung D900.
Try an update of PC Studio 3.0
http://uk.samsungmobile.com/supports/softwaremanuals/pcStudio31.do?phone_model=SGH-D900&pc_studio=PCStudio3.1&manualsSize=4&softwareSize=3
Take your time with the connections from phone to PC.
Use the recommended cable, it works better than Bluetooth.
Jan 03, 2008 | Samsung SGH-E900 Cellular Phone
Western Digital WD Elements 1 TB USB 2.0 Desktop External Hard Dri Logo
166 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
