Question about Garden
Cub Cadet Repair Manual
Battery is not charging
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Did wire fall of Regulator?
What year Cub? they've been making them since the 60's
Posted on Nov 21, 2013
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 8 Answers
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Posted on Aug 16, 2009
  • 142 Answers
SOURCE: cub cadet repair manual
partstree.com may have then or call the manufacture
Posted on Sep 23, 2009
Cub cadet lt1050
Is the red light on before you engage the blade?
There may be a blown diode in the charging circuit.
Battery- If this light illuminates while the engine is
running, it indicates that the battery is in
need of a charge OR that the engine's
charging system is not generating sufficient
amperage. Refer to Battery on page 26 of
this manual for the properbattery charging
procedure or have theengine's charging
system checked by a Cub Cadet dealer.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Aug 27, 2014 | Garden
Battery will not charge on cub cadet 1515
is it not charging or is the battery bad and can't be charged anymore there only good for a few year
Aug 28, 2012 | Cub Cadet Garden
Does a cub cadet model 2544 use a alternator to charge the battery my battery is not holding a charge alredy put in a new battery
yes it has a low amp charging system charge the battery and disconnect the neg cable install a test light between the cable and the battery if the light is on there is a draw unplug the harness that goes to the charging system if the light then goes out the diode on the charging system is bad
Aug 06, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
May 12, 2012 | Cub Cadet Garden
Troulbe shoot charging system on cub cadet 582
is the battery just bad the only last a couple years for lawn mowers
Apr 07, 2012 | Cub Cadet Garden
Cub cadet repair manual
Sep 23, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
