Question about Onkyo M-282 2-Channel Amplifier
I've got an Onkyo M-282 with one channel that just died. Upon visual exam, there seems to be absolutely nothing wrong with it (the caps are all flat, not puffing, no broken components or smells...).
It doesn't have a fuse protecting the speaker outputs. Also upon first inspection, I had to do a reset as the standby light was staying red and flashing. When the reset was done, the standby light went yellow and I got sound from the left side.
  • Anonymous Jun 08, 2017
    Were you able to fix this?
    Sergeant:
  • 308 Answers
Likely you blew your outputs Transistors or mos fets, you cannot be sure without ohm meter. usually when one side goes out the protection kick in on both chanels
Tony
Posted on Nov 21, 2013
  • 54 Answers
SOURCE: onkyo amplifier
Is power coming out of transformer at the right voltage. Also may have a power i.c. shorting to ground.Final anp i.c. may have a place to go to ground through a shorted capacitor.
GOOD LUCK
Big Red
Posted on Dec 29, 2007
  • 85 Answers
SOURCE: speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Posted on Jan 18, 2009
97F350diesel
  • 1326 Answers
SOURCE: i have 1 center channel
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Posted on Jan 01, 2010
  • 62 Answers
SOURCE: Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
Posted on May 24, 2010
SOURCE: Onkyo TX-SR576 7.1 Rear Channels problem
Have the same amp and speakers, had some trouble getting the imput signals sorted from the HDMI input as im using a PC with HDMI output from the mother board and Windows Media Centre. havent tryed using the mic set up yet.
Did you resolve the issue? have you tried the 7.1 outputs
Posted on Jun 02, 2010
Sound problems with an Onkyo receiver and a FIOS Set Top Box
If you are not hearing dialogue, then check your center speaker. Most voice tracks are routed to the center channel
Apr 06, 2017 | Onkyo Audio Players & Recorders
M282 onkyo amplifier died during a movie. During one of the heavy bass scenes (a thunder storm), the amplifier just died. I verified all of the connections, and they are good. Tried pressing the on off...
If your speakers are not in good condition you may have floated the cones inducing DC feedback into the amplifier, Im not sure if this amp has internal protection fuses, but I would check them and if so replace with same specification fuses. Sometimes we get lucky... Good luck
Apr 22, 2011 | Onkyo M-282 2-Channel Amplifier
Onkyo M-282
May 24, 2010 | Onkyo M-282 2-Channel Amplifier
7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Jan 06, 2010 | Onkyo M-282 2-Channel Amplifier
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
Speaker distortion on high end
Dec 18, 2008 | Onkyo M-282 2-Channel Amplifier
ONKYO M282 AMP seems to have lost all mid and low range
It's probably salvagable but I doubt it will be cheap or easy. Most likely you have one or more ruined output transistors. If you're into taking things apart and soldering, it might be easy for you. Just look
for abnormalities on the transistors, usually a little hole in the center of them or blistering. Replace those and you'll either have it back to sounding good or much closer to it. Most output transistors do not fail without showing visual evidence of it.
Nov 17, 2008 | Onkyo M-282 2-Channel Amplifier
Onkyo M-282 2-Channel Amplifier Logo
205 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
