Question about Canon F-502 Calculator
How do i use bedmas - Canon F-502 Calculator
  • Canon Master
  • 7,993 Answers
BEDMAS is a mnemonic device used to help you remember the order of operations in the evaluation of mathematical expressions.
B stands for Brackets OR Parentheses.
E stands for Exponent(iation)
D: division
M: multiplication
A: addition
S subtraction
I will amend the device to introduce the ROOTS, and to separate the levels of priority by --
B--ER--DM--AS
That means that raising to a power E and extracting a root R have the same priority. When these operations follow one another the order is from left to right.
Division and Multiplication have the same priority levels. When they follow one another, the order is from left to right.
How to use : RECURRENTLY
Look at the expression and locate the brackets (parentheses).
If there are many sets of parentheses start at the left and take care of the leftmost set. When inside the leftmost set of parentheses use B-ER-DM-AS again, and again until there is only one term left.
If there are embedded parentheses start from the deepest.
Let us simplify a bit.
Inside first set of bracket
Are there brackets: No
Are there Powers or Roots: yes. take care of powers and roots starting from the left until there are no more powers or roots
Are there multiplications or divisions? Yes. take care of multiplications and divisions starting from the left until there are no more divisions or multiplications.
Posted on Nov 21, 2013
  • k24674 Nov 21, 2013
    Same for adiition subtraction.
How to do Order Of Operations and algebraic expressions with division and multiplication and subtraction and addition for 6th grade ONLY
here you go.
Grade 6 Math Circles Algebra Order of Operations (BEDMAS) - CEMC
www.cemc.uwaterloo.ca/events/mathcircles/2013-14/Fall/Junior6_Oct8.pdfGrade 6 Math Circles ... Suppose you are asked to evaluate an expression that looks something like this ... When an expression contains many operations, we must be careful of what order we do ... sion and multiplication, and finally addition and subtraction. ... According to BEDMAS, division is a higher priority than addition. How to do Order Of Operations and algebraic expressions with division and...
Apr 24, 2017 | Office Equipment & Supplies
2negative 3 plus 3negative 3
Just want to make sure that we are on the same page.
2^(-3) + 3^(-3)
2 to the exponent -3 + 3 to the exponent -3
Because of BEDMAS, we have to do the exponent calculations first and then do the addition between the two terms last.
The rule of negative exponents is you put 1 over the base to the same exponent, but change the exponent from negative to positive.
=1/(2^3) + 1/(3^3)
= 1/8 + 1/27
To add or subtract numbers, we need a common denominator.
Let's factor 8 and 27 to get the lowest common multiple.
8 - 1 2 4 8
27 - 1 3 9 27
Nothing in common to eliminate, so we have to use 8 x 27 or 216.
27/216 + 8/216 = 35/216
Good luck,
Paul
Mar 11, 2017 | Homework
13 inch round pan 2 inches deep =how many cubic inches
You can view this question as what is the surface area of the 13 inch round pan, and then with it being 2 inches deep, calculate the volume.
Surface area = pi * r ^ 2, where r is the radius of the pan
In this case, the diameter is 13 inches, so the radius will be 6.5 inches.
Putting it into the formula, we get surface area = pi * 6.5 ^ 2.
Because of BEDMAS, we have to do the square before we multiply.
Surface area = pi * (6.5 ^ 2)
= 132.7square inches.
To get the volume, we multiply this surface area by the depth of 2 inches.
Volume = surface area * height
Volume = 132.7 * 2
Volume = 265.4 cubic inches.
Good luck,
Paul
Nov 02, 2016 | Office Equipment & Supplies
How do you simplify the exponent on the calculator?
I assume 13m/2 is the radius of the sphere and you are trying to calculate the volume of the sphere.
The first thing we have to think of is BEDMAS, the order of operations, as some calculators do them correctly, while others do not. Let's be safe and do the BEDMAS manually so we know we will get the correct answer.
B - brackets - enter 13/2 in the calculator - hit enter
E - exponents - with the answer from the first line in the calculator, use the hat key (^) or the y to the x key to raise this to the third power (exponent 3).
M - multiply - with the answer from the line above, multiply this by pi or use what you are instructed to use or use 3.14159, then multiply by 4 and divide by 3.
You should have your answer.
Good luck.
Paul
Jul 12, 2015 | Office Equipment & Supplies
How to convert Fahrenheit to Celsius
Put 70 in for F, and apply BEDMAS, the order of operations, brackets, exponents, division and multiplication, and finally addition and subtraction. In this case, we have to do the brackets first before the multiplication and division. The answer should be 21 degrees Celsius.
Feb 24, 2015 | Office Equipment & Supplies
Convert Fahrenheit to Celsius 70F to C by applying the formula (F-32)*5/9
What is the answer to to this (x^5)^3(x^3)^4
We have to follow BEDMAS, the order of operations, where brackets are first, then exponents, followed by division and multiplication, and finally addition and subtraction.
Also, we have to use the exponent law of an exponent to an exponent, we multiply the exponents with the same base.
If we forget this, we can always do it the long way.
(x^5)^3 = (x^5)(x^5)(x^5) = x^15
Similarly, (x^3)^4= (x^3)(x^3)(x^3)(x^3) = x ^12
Now that we have done the exponents, we can multiply x^15 by x^12 and get x^27.
Good luck.
Paul
Oct 05, 2014 | Office Equipment & Supplies
5I+5(I-31)=55 how do i solve this
Start by using the distributive property to expand the term 5(I-31)=5*I-5*31=5*I-155.
Rewrite the equation as 5*I+5*I-155=55
Combine the terms with I, this yields 10*I-155=55
Add 155 to both sides of the equation 10*I-155+155=55+155
you now get 10*I=210
Divide both sides of the equation by 10
(10*I)/10=210/10
Cancel the 10's on the left and divide 210 by 10 to get 21
Thus I=21
Basically you use the priority order of operations BEDMAS backwards
Feb 13, 2013 | SoftMath Algebrator - Algebra Homework...
Canon F-502 Calculator Logo
77 people viewed this question
old marine
old marine
