Question about Behringer Ultratone K450FX Keyboard Amp / PA System
I need a part for a Behringer Ultratone KX450FX amplifier
I am repairing this amplifier, which keeps blowing fuses. I have isolated the fault to the transformer, and I need to locate the part.
  • 9 Answers
SOURCE: Fuse blowing on start up on Behringer PMH 518M
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
Posted on May 28, 2009
  • 10 Answers
SOURCE: Behringer PMH 518 M
I just fix this unit,
1 Nch IRF140N
1 Pch IRF9140N
1 0.1 ohm 3w resistor at one of the mosfets
1 47 ohm 1/4w
1 220ohm 1/4w
Posted on May 12, 2010
Grubhead
  • 5056 Answers
SOURCE: I have a Behringer EP2000 amplifier and only one
A fuse blows like that because of an overload. Nine times out of 10 it will a transistor that is acting like a piece of wire. If you have a Ohm meter try the output devices. You will soon find the faulty part as it will be like you have touched the test probes together!
Posted on Dec 08, 2010
  • 5603 Answers
SOURCE: I own a Behringer Ultratone
This is most LIKELY an electronic problem... possibly in the final power amp. Repair may be a simple failed component or a mass number that fail like a stack of dominos. Take it to a shop for repair.
Posted on Apr 16, 2011
  • 5603 Answers
SOURCE: i replaced the transformer and
Transformers rarely fail... you wasted money on that... Likely one of the rectifier diodes/module or filter caps has shorted. Continued use will burn out the transformer. It is humming because it is overloaded with failing components.
Posted on Jul 04, 2011
Something blew during a loud performance and now it produces continual high-freq feedback that can't be controlled.
The speaker may be blown, but if you're getting continual Hi-freq feedback that is not resolved by lowering the volume know, you need to take this to the repair shop.
Apr 28, 2015 | Behringer Ultratone K3000fx 300w Keyboard...
Suddenly stops working and have to wait for a few minutes for it to work again.
Probably a component in the power supply is overheating, You need to take it to the repair shop.
Apr 26, 2015 | Behringer Ultratone K3000fx 300w Keyboard...
Where can I get a Type T 6.3 AH 250V fuse for a K3000FX 300Watt Keyboard Amp?
Start with a 5 amp fuse and see if that holds. If it doesn't go to 10 amp. If that pops, you will have a power supply or amplifier fault. Good luck
Aug 12, 2014 | Behringer Ultratone K3000fx 300w Keyboard...
Behringer K3000FX Ultratone Keyboard Amplifier from day 1 has had a slight buzz
For a start , check headphones out.
• if it don't work , check power supply of the preamps.
• If it is OK, could probably the main amp have fail.
But check the main volume .
Sep 11, 2012 | Behringer Ultratone K3000fx 300w Keyboard...
How to replace fuse in case it blows..?
The answer is you DON'T replace it without repairing the cause, lest you cause further damage to the internal components. Often the fuse is contained in a plastic "boat" that is right alongside where the power cord plugs in. You have to remove the cord to lift the tab on the boat.
May 04, 2011 | Behringer Ultratone K1800fx 180w Keyboard...
HI, I just need the value/taper of the 30mm slide potentiometer used in the equalizer of the Behringer K1800XF.
The sliders in almost all of the EQ's in Behringer are linear taper (B). The values are usually 50K. Fo replacement make sure you get matching mounting spacing. Almost all Behringer pots are made by ALPS.
Note that the rotary volume controls are G (graphic) taper, often 50K and are hard to get. trying to get these from the Behringer parts distributor was futile... gave up after 4 months wait.
Apr 28, 2011 | Behringer Ultratone K1800fx 180w Keyboard...
I own a Behringer Ultratone K3000fx 300 watt PA/Keyboard Amp that stopped putting sound out. The amp is getting power just not putting out any sound at all. Just wondering if this is an easy fix or I...
Apr 16, 2011 | Behringer Ultratone K3000fx 300w Keyboard...
How do i get to the power amp? fuses keep getting blow and i dont want to repair it but the speaker is good. i want to remove the speakers and power amp from the box
Power amp is through the back. There are about 5 transistors in the output section that are likely blown and they are realatively inexpensive ones. Also the poower supply is a full-wave centertapped bridge and filter caps or diodes could have shorted... all are fairly inexpensive fixes.
Here is schematic:
http://elektrotanya.com/behringer_k1800fx_sch.pdf/download.html
Jan 06, 2011 | Behringer Ultratone K1800fx 180w Keyboard...
Behringer Ultratone K450FX Keyboard Amp / PA System Logo
75 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
