Question about Powershot Tool Company Tools & Hardware - Others
It quit working after putting 10 staples--- spring will not return
Handle will not return to push more staples through It acts like the return spring broke
Sounds like you have a damaged or bent staple stuck at the business end' of the machine.
Posted on Nov 21, 2013
3 Suggested Answers
SOURCE: after filling with staples, could not get gun to
pull the stapeler loader out there should be a spring that keeps the staples pushed foward 2 check that you have the correct size staples also check where the staples come out possibly there is one stuck in the chamber a needle nose plier should pull the bad on out there also maybe a way to flip open the nose of the stapler to clear the problem
Posted on Apr 12, 2010
SOURCE: my powershot doesnt work seems like spring or some thing broke
Mine was stubborn right out of the box. Didn't want to "fire". Put a tiny drop of light machine oil where staples exit. You can also remove staples and do some swabbing around sliding parts with same oil and a QTip. Fixed mine. Just be sure you have right staples for your model. Bought my staples in the tool dept. at WalMart.
Posted on Dec 01, 2011
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
I need instructions on how to refill the Arrow T50 Staple Gun. I have the stapler and ran out of staples. I can't get the staples into the track.
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Mar 23, 2011 | Arrow T50 Staple Gun Tacker
How to refill
In the back of the handle at the end, there is a clip that needs to be flipped and then pull the tab downward while pulling outward. It does not open per say, but you pull the spring loader out of the handle. You will see two rails inside of the opening once the spring loader is out of the way, just lay a strip of staples on the rails and re-insert the spring loader and clip in the reverse order that you too it apart. It works very similar to a normal desk stapler. The spring loader pushes staples into the staging mode so when the plunger pushes downward it pushes the staple with it. I hope this helps in good luck!
Mar 29, 2010 | Heavy Duty Stanley 2014413a Staple Gun...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
The spring has come out and we don't know where to put it
The Spring keep the Staples against the Stapler driving tool. Normally there is a metal pad to push against the staples, a rod that goes thru the Spring with a metal latch that locks inside the Stapler.
Jul 01, 2009 | Stanley Staple/Nail Gun Elec
How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Jun 08, 2009 | Arrow T25 Staple Gun
T50 stapler gun it worked for about 15 applications then just stopped, it's not jammed, it has staples loaded properly & firing off staples repeatedly doesn't work nothing comes out??? Why would it just...
It sounds like a manufactor defect in wire harness or premature silinoid burn out,
or you simply need to make sure you plug into and outlet that works. Could be cheap but not worth repair,return as defect if possiable and buy new one before.
Please rate. Thanks jj505
Mar 27, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Staple gun has staples but quit working.
I hae the same problem. I don't know the real names of the parts so I will make up my own and try to describe them. The problem with mine is that the "hammer" (the piece in front that slams down on the staple and shoots it out) is broken. The "hammer" has two notches that the tension spring (actually a metal bar with two tongs not to be confused with the spring the returns the handle to the at rest position) fits into. One of these notches on the hammer is broken. Therefore one side is not attached to the tension spring the causing the other side to slip off and since the hammer is not connect to the tension spring you get no resistance. Unfortunately I could not find anywhere that sells a replacement peice.
Sep 18, 2008 | Black & Decker 5700 Powershot Forward...
How to replace spring
Hope the following is clear if not write back and I'll try to clarify, if you look at the body of the stabler molded to the body there is a bump that is round on the botton and kinda notched on top. the round part of the spring fits around the bump. The spring has a straight side and bent side. the straight side rests against the a flat bump which is slight back and lower than the round bump. the bent side clips into the notch on the handle (clip this end in last) I used a plier but there is very little tension involved the spring just returns the handle to the at rest position,
Aug 14, 2008 | Black & Decker 5700 Powershot Forward...
Tools & Hardware - Others Logo
120 people viewed this question
Top Powershot Tool Company Tools & Hardware - Others Experts
Are you a Powershot Tool Company Tool and Hardware - Other Expert? Answer questions, earn points and help others
