Question about Mitutoyo 293 831 Electronic Digital Micrometer0 To 1 In
Miyuyoyo 293-761-10 displays E--o5 wont work
Put it away, next time I went to use it, it displays E--o5 and wont function
0-1 mitutoyo micrometer reads E--o5 i have replaced battery and cant make it go away?
A data sheet I got with my Digimatic 572
series scale says:
"Keep the scale unit free from water and oil.
Do not dip or sink the scale unit in liquid.
If E--05 is displayed, wipe the scale surface
with a soft cloth. Apply a slight amount of
low viscosity oil, such as CRC3-36, to the
scale surface to keep out water."
mitutoyo micrometer reads o5 Google Search
Mitutoyo Support
http://www.mitutoyo.com/
Jun 29, 2017 | MADE Computers & Internet
Ford Sync not functioning
I've had the SYNC stop working twice for no reason. The first time, after checking fuses and such and not finding a problem, I just disconnected the battery cable for 10 minutes, then reconnected and everything worked again. Went straight to that the second time it happened and was back in action straight away.
Mar 16, 2013 | 2009 Ford F-150
Honda 4 wheeler problems
I have a Honda 350 4 wheeler model trx350 4x4 ex I was riding put away the next morning I went out I could not get the auto reverse to shift. I can use the manual shift. All the forward shifts work any ideas
May 12, 2012 | Motorcycles
It was working fine til I went on holiday. When I came back it wont even switch on. Is it cross because I went away without telling it!?
These machines are very sensitive and you have obviously hurt its feelings!!
I suspect you had a power cut while you were away and it may have been a very short one and you may not even have noticed it. Were any other electrical items showing the wrong time? Is there a smell of burning from the machine? If so then the power supply will have blown. If you can get to the psu then check the glass fuse as it has probably blown. You MUST replace it with EXACTLY the rating. Hope fully that will fix it.
Next time dont be rude to it.......
May 12, 2011 | Office Equipment & Supplies
Radio reads off and wont work
The anti-theft program has kicked in (usually activated by the wrong code being put in 2 times). Turn the ignition key to position 1, and turn the radio on. After 1 or 2 hours, the word code will be displayed. At this time, if you put in the correct code, the radio should work.
Mar 18, 2010 | 2000 Volvo V40
Error code "E--o5" on display. How can i fix it?
I had the same problem.I think oil or coolant got into the buttons,causing an electrical problem. I took the battery out and put a couple of drops of alcohol on the buttons and inside battery compartment,then blew it out really good leaving the battery out and drying under a light for about an hour.
Nov 10, 2009 | Mitutoyo 293 831 Electronic Digital...
Mazda 3 (2006) Information Display panel is blank
I took it to the dealer. They fixed under waranty. The new issue is the flash and beep confirmation upon double locking the doors no longer works.
Apr 15, 2009 | 2004 Mazda 3
I have a pyle pld5mu and the screen is dark
Hey honestly what you need to do is send the unit back to pyle and they will repair it. I have the same issue 2 times. What they say is the players power supply went out and that 80% of issues with the pyle products are improper installation. I am selling mine and you should do the same after you get the player back. I hope I could help
Shawn Contreras
Jan 08, 2009 | Jensen VM9510 Car DVD Player
Display turned off, but i can make and receive calls
If you take the battery out then with the battery out plug in the charger, this worked for me.
Jun 15, 2007 | Motorola Mobility RAZR V3
Mitutoyo 293 831 Electronic Digital Micrometer0 To 1 In Logo
82 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
