Furnace does not fire up but fan runs
Gas is on thermostat is working and calling for heat.
  • 148 Answers
For older model check pilot light a newer model check limit switch if you igniter is lit.
Posted on Nov 24, 2013
4 Suggested Answers
  • 10 Answers
SOURCE: Furnace starts, but no heat nor fan operation.
If youe burners fire off it's not the transformer. It suonds like the fan/limit control. Try to turn the fan switch on the thermostat to the on position and see if the fan comes on, if it does leave it on and turn the heat on and see if the heat works that way. If so it would be the combination fan/limit control.
Posted on Feb 07, 2008
  • 659 Answers
SOURCE: Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Posted on Jan 05, 2009
  • 659 Answers
SOURCE: Lennox G40UH-60D-135-14 Furnace will not ignite
Do you have an inducer on the unit (no access to the lennox model number tonight)? That is a motor that comes on shortly before your unit fires that blows the combustion gases up through the flu. Does this motor come on at all if you have one? If it does and the furnace will not light, then there is a device on the unit called a pressure switch. This switch has two wires to it and a small tube that leaves it and goes to the inducer housing. Remove the tube from the inducer and blow into and draw in air lightly or until you hear clicking noises. Replace the hose and try again. Sometimes the pressure switch gets stuck but can also go bad. If everything is coming on all the way up to ignition but the unit won't come on, then it's probably one of the limit switches that need to be reset. These are little disks about the size of a penny and have two wires going to it. In the middle is a small button that can be pushed to reset it. Some units have 2 to 3 and others have more. You have to use a flash light and look all in the unit around the burners and around the flu pipe looking for the limits. Once you have found them all and tried to reset the unit, then try to start it up again. Hope this helps.
Posted on Apr 04, 2009
Furnace wil, not ignite when calling for heat
For this answer, we need a model and serial number.
Generally, be sure the power is on, does the heat moving device run? (Fan for air, or pumps for water)
Nov 02, 2017 | Heating & Cooling
Honeywell thermostat will not work when put on automatic
Depends on what type of heat you have...if it is electric, it could be your thermostat (some electric heaters use contactors & rely on the thermostat to switch the fan on). Heat pumps also use the thermostat to switch the fan on in heat & cool mode. Most electric furnaces use a sequencer to switch the low speed of the fan whenever there is a call for heat. Gas furnaces use either a fan/limit controller (if the unit is older) OR a circuit board based on time (after the thermostat calls for heat). SO depending on the type of system you have, it could be a bad sequencer, controller, relay, thermostat, or control board. Hope that helps.
Dec 17, 2013 | Heating & Cooling
I have a Honeywell programmable thermostat with a York high efficiency furnace. To turn the heat on, the thermostat "clicks" and cycles the furnace through startup (warm the fire starter, turn on gas,...
Well, it is a computer, and they all glitch, now & then, you say it clears with a power off, and thus resets it, It maybe a thermostat, flaking out, they do that, but the 6'o'clock, thing being the "Or" that sets it apart, I wonder if it isn't just a faulty control unit, as two together is too many, for a single cause, now, it sort of points there, but also, may sound silly but first, of there is any, Check your backup battery..
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
Fan blows but no heat/fan won,t shut on and off in the auto mode
Certain gas furnaces will default to high speed fan ON any time a high temp limit opens or the 24 volt transformer fails. Please respond to describe your make of furnace and if the fan runs only when your thermostat calls for heat or if that makes a difference.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
My goodman gas furnace is not kicking on. the light on the unit is saying that it should be working but it is not. there is no pilot light, the fan is working the heat is not
If you are not getting any codes from the board, then the furnace is not getting a call for heat from the thermostat. A wire may have come off, the thermostat not properly wired, or a break in the stat wire. On a call for heat, you should have 24vac between W and C on the circuit board. This will let you know if you are getting a call for heat all the way back to the furnace.
Oct 01, 2009 | Goodman GMS90703BXA Heater
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Feb 07, 2008 | Heating & Cooling
Heating & Cooling Logo
79 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
