Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
Chainsaw troubleshooting had to start i got to put gass down the carb to start
I have the kit craftsman chainsaw 18 inch, with 42 ml engine. The problem is when you finally get it started, it dies when you give it gas. I need an answer please?
I see this problem a lot, so I just decided to research the problem. Yes, it is a known problem with chainsaws. Put down to fuel starvation for a number of reasons.
dirty/stale/contaminated gas
clogged fuel filter
clogged air filter
incorrect carb gas to air mixture
wood particles in carb jet
loose carb
http://www.bing.com/search?q=craftsman+chainsaw+dies+when+you+give+it+gas&qs=n&form=QBRE&pq=craftsman+chainsaw+dies+when+you+give+it+gas&sc=0-0&sp=-1&sk=&cvid=1987a3ed5bd649c2a6cb89f99f270d8b
Nov 10, 2015 | Craftsman Garden
I have trouble starting my 738 partner chainsaw
well was the gas fresh
is it even getting to the carb
have you sprayed carb cleaner into the carb and then see if it starts
yes it does
get a new carb
Aug 19, 2014 | Garden
Sounds like the engine decompressor is stuck shut remove it clean up with carb cleaner and try again.
Jul 04, 2014 | Stihl 009l
Starts easy but dies after a couple seconds
Does the primer pump maintain a fuel supply when running.? If not then you probably still have an air leak somewhere between the tank and the carb.
Could be fuel starvation, check carb High Low needle settings and disphrams.
Aug 26, 2012 | Husqvarna 2-cycle Straight Gas String...
Craftsman chainsaw has no power
I would first check your muffler and screen in muffler to make sure it's not partially plugged. Personally I think it sounds like a fuel delivery problem,I would make sure you change your Fuel filter and check your lines for being cracked and or collapsing from ethonal in gas these days. then I would put fresh gas in it and see if it helps.you also need to clean carb and then readjusr carb after cleaning carb
Jan 02, 2012 | Garden
I have a Echo chainsaw model 452Vl and am not able to start it.
Hi, It does have a filter of sorts but is on the pickup inside the tank and should not need changed. Drain the fuel mixture and check all of the plastic lines and primer bulb for cracks or kinks. Put in a fresh fuel mixture that has not been sitting, (They don't run on old mix) and try starting again. The thought process is that if it starts on the starting fluid it can only be two things, old fuel or no fuel. If the fuel change doesn't work it is probably not getting fuel thru the carb, these oil mixes gum up rather quickly and if it sat for awhile with fuel in it it may need the carb cleaned. Good Luck to you, hope this Fixsya!
Feb 23, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My Poulan 3500 chain saw will not start
My guess is that one of your fuel lines has a crack or small hole in it. Inspect these and replace if needed. let me know how it goes.
Feb 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Tryed to start stored engine oil came up in carb.
Hi, I would start by putting in a new spark plug. drain gas, and put in fresh hi octane gas.
If this doesn’t work for you please write back, Thanks,
Nov 22, 2008 | Garden
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
23 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
