Question about Cameras
Battery needs to charge for how long before it will come on
Camera is not turning on
    Top Expert:
  • Cameras Master
  • 6,702 Answers
This depends on the battery you want to charge and the charger you use. But when both are in good order, you should be able to switch on your apparatus after one or two hours. The battery will not be charged, but should be able to show it is alive.
If the battery is charging for hours and it is not able to power anything, it could be defect.
If you are charging a battery, or batteries in the camera, try to charge them outside on an external charger. When the charger has a light burning that should be a sign it works. Only if you have a multi meter and you can work with it, you can check the battery. It should give a reading if a few tenths of a volt above the value printed on the battery.
Posted on Nov 21, 2013
I have sony cybershot dsc 10 digital camera but it dsn't power on batery charge is full
Please make sure that the Battery in the Camera is fully charged.
Please check if the issue is with the battery charger. Make sure that the Charge Lamp in the Battery Charger is lit when connected to the Wall outlet.
You can try recharging the battery pack for almost 6 hours as initial charging.
If you've another battery pack, try using the same to check if the issue is with the Camera or with the battery.
You can also try turning on the Camera by connecting the optional ACL-S5K AC Adapter. This Adapter can be used for turning on the Camera, it cannot be used to charge the battery pack. For charging the battery in the Camera, the supplied battery charged needs to be used.
If the Camera is not turning on using both the AC Adapter and new battery, then the Camera may require service.
Thanks for using FixYa.
Jan 10, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
I have sony digital camara but it dsn't power on batery charge is full
Jan 10, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
I have sony digital camara its not power on plz help me
Jan 10, 2011 | Sony Cameras
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Got a brand new M320. Charged up the battery and
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 02, 2010 | Kodak EasyShare M320 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Sony dsc-s600
1= Use rechargeable battery cells and must be fully charged.
2= Check battery terminals in camera battery compartment. Must be cleaned and shiny.
3= Sony camera DCS-S600 won't charge batteries through USB cable plugged in PC. You need external battery charger to charge battery cells.
Oct 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Not charging?
Please plug the camera charger in AC Outlet and hook it to camera. Check camera power turn ON, works fine? if OK, switch it to Standby / Off mode. Attach battery and check any charging light lit? If yes, leave the camera on charging position for 4-5 hours until its charge light flashs or turn Off. battery is chaged now. Have fun :)
Aug 13, 2008 | Sony Handycam CCD-TRV37 Camcorder
Cameras Logo
69 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
