Question about Xerox DocuMate 162 Pass-Through Scanner
E15 documate 162 - Xerox DocuMate 162 Pass-Through Scanner
I have xerox dc 250 machine, it shows fault code 077-909, paper jam at tranfer module but i checked there is no paper in it??
Hello friend, you are not alone !!!!
From http://www.copytechnet.com/forums/xerox/28764-dc-250-fuser-problem-077-909-a.html
At the bottom of the page it says.......
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
Sep 03, 2014 | upbright AC / DC Adapter For XEROX...
Showing error code 8
paper jam but take care if the lamp with any color instead of red it will be no error
Jan 13, 2014 | Xerox DocuMate 162 Pass-Through Scanner
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
I have 2002 dodge Dakota I sparked the battery and now the headlights taillights cargo and dome and dash lights don't work I replaced headlights switch checked fuses and replaced computer idk what to do...
Check these fuses again:
In the Power Distribution Center (in the engine compartment, left fender panel) Fuse #3 (20 Amp) Fuse #7 (40 Amp), Fuse #12 (20 Amp) and in the Junction Block (on the left end of the dash) Fuse #1 (15 Amp)
Use a test lamp and make sure that these fuses have power. All of these fuses should all have power at all times, regardless of ignition switch position. If they are all good and have power, then you probably need to replace your Central Timer Module. All of the circuits you listed are dependant on this module for operation.
The Central Timer Module is located at the left kick panel.
Central Timer Module System
The CTM is available in a BASE or a HIGHLINE configuration. The BASE and HIGHLINE CTM provide the following features:
• Battery saver functions for exterior and interior lights
• Cargo lamps chime warning
• Courtesy lamps
• Dome lamps
• Dome lamp defeat
• Door ajar switch state
• Fog lamps
• Headlamp time delay
• Intermittent wiper controls
• Low and high beam head lamps
• Optical horn
• Park lamps
In addition, the HIGHLINE CTM provides the following features:
• Central locking
• Door lock inhibit
• Driver door unlock
• Enhanced accident response
• Horn chirp
• Optical chirp
• Power door locks
• Remote keyless entry (VTSS)
• Remote radio
May 03, 2011 | Dodge Dakota Cars & Trucks
How do i get my th-a9r to play dvd-rw
You can't. The Laser will only Play +R & +RW.
Non-playable discs
• DVD-ROM • DVD-RAM • DVD-R • DVD-RW
• CD-R* • CD-ROM • PHOTO CD • CD-RW*
* Audio formatted CD-R and CD-RW can be played.
• Playing back discs list as "Non-playable discs" above may
generate noise and damage speakers.
Apr 23, 2011 | JVC TH-A9 System
Flash card error appears on the screen and stops the camera from shooting
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory card
Jan 28, 2011 | Olympus EVOLT E-410 Digital Camera
Olympus E-300 Evolt when you press the shutter button to take a picture, the shutter rapidly repets for about 9 times
Jan 27, 2011 | Olympus Cameras
How do i change the time on my phone
Try this: • PRESS PROGRAM • DIAL ** • DIAL 1234 (SYSTEM PASSWORD) • DIAL 000 (DATE AND TIME PROGRAM NUMBER) • PRESS THE NEXT KEY • ENTER THE YEAR • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY UNTIL DESIRED MONTH IS DISPLAYED • PRESS THE ARROW (FWD/DND) KEY • ENTER THE DAY OF THE MONTH • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY UNTIL THE CORRECT DAY OF THE WEEK IS DISPLAYED • PRESS THE STORE KEY • PRESS THE NEXT KEY • ENTER THE HOUR • PRESS THE ARROW (FWD/DND) KEY • ENTER THE MINUTES • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY FOR AM OR PM • PRESS THE ARROW (FWD/DND) KEY • PRESS THE SELECT (AUTO ANSW/MUTE) KEY FOR A 12 OR 24 HOUR CLOCK • PRESS THE STORE KEY • PRESS THE END (HOLD) KEY • PRESS THE PROGRAM KEY TO EXIT PROGRAMMING
If this helps you, please rate. Thank you
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
Xerox DocuMate 162 Pass-Through Scanner Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
