Question about Boston Acoustics TVee Model 30 Soundbar with Wireless Subwoofer
Standby mode If the tv is off, the unit frequently goes into a freeze mode where all the lights go on and the volume is set and fixed at a low level. If I turn the soundbar unit off and then on, it works fine
  • Jon Savas
    Jon Savas Nov 23, 2013
    Sorry should have been clearer. The sounbar connects to the digital audio out from the tv via optical link. The cable box and DVD connect to the tv via hdmi
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
If you have your soundbar connected via HDMI, look for an option to disable the link between your TV and your soundbar (when this option is on on the devices connected toghether, when you turn off/on any of them automatically does to the same with all devices).
Posted on Nov 21, 2013
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
Nov 26, 2015 | Sylvania Televison & Video
MY POWER MAX 5.8 SAYS THAT MY VOLUME IS OFF ON ONE HAND SET--HOW DO I TURN IT ON? THANKS EILEEN CARTER beileenc@bellsouth.net
There are different ways to adjust the ringer and speaker volume on your handset. Please see your owners manual for model specific instructions.
On most single handset units:
Ringer volume: Press the volume up or down arrow rapidly to change the ringer volume.
Speaker volume: When talking on the handset press the volume up and down arrow to increase or decrease the volume.
On other models:
Ringer volume
In standby mode, press the volume up key or volume
down key on the handset or base to select one of three
ringer volume (Off, Low, or High).
Earpiece and Speaker Volume
You can select from among of six volume levels on the
handset, and ten levels on the base. Pressing the
volume up key or volume down key on the handset or
base during a call will change the earpiece or speaker
volume. This setting will remain in effect after the
telephone call has ended.
If you press the volume up key when the earpiece is at
the maximum volume level, an error tone sounds.
The error tone also sounds if you press the volume down key at the lowest volume.
Sergio
Mar 13, 2008 | Lands Phones
How do I get the electronic digital display to light up.
Hi Dudley, I would suggest that you try the following reset:
To do the reset you need to turn the receiver on then on the front panel of the receiver press and hold the "VIDEO1/VCR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
Thanks, JT
Sep 12, 2015 | Onkyo Tx-900 Quartz Synthesized Tuner...
Tv freezes in standby mode
If it is still under warranty, TAKE IT BACK
Jul 28, 2012 | Sony 40 KDL40BX420 LCD TV
Dpx-u5120 dosent show subwoofer option in function mode , how to fix it ?
I manage to slove to my DPX-U5120 Subwoofer level adjustment. In STANDBY mode, Press the Main Volume button and turn to Setting, turn until you find the SW Preout, Swith to normal mode, its won't work if u switch to REAR
Go back to CD/USB Mode, Then Press the Main Volume and find Audio Adjustment and now u can find the Subwoofer Level , Sub Phrase and Sub LPF adjustment.. Um Glad i found this and Happy Setting
Mar 22, 2012 | Car Audio & Video
My kv34hs510 will not power up and the standby light flashes 6 times and then repeats.What is wrong? Ron....
There is a power issue,tv goes into standby (safety) mode. For self-diagnostics, press Display,channel,5,volume - minus not plus,then press power. You have no horizontal output,check IC206,C516,C515....for service mode press Display,Channel,5,volume + plus,then power,press8,then enter......hope this helps....
Mar 08, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Tv try to turn on as soonest i am pluging it to the outlet, it's that normal?
Yes, its normal as TV remember its last status like channel number/ AV input, volume level, video settings etc in its memory. If you put TV in standby and then unplug it, TV will turn on in standby mode after replugging back in.
Thanks.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
My 605 turns off and red light blinks when volume goes past 58
Shorted speakers can cause the unit going on protection mode (the red light blinking) when a certain volume is reached.
Test with a set of replacement speakers.
If it is not the speakers, it is probably transistors in the amp final or something nearby. Test also input output board.
Apr 27, 2009 | Onkyo TX-SR605 Receiver
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Service menu
How to Enter Service Mode
1. Turn on the main power switch to place this set in standby
mode. (LED will light in red.)
2. Press the buttons on the commander as follows, and enter
service mode.
PRESS these buttons in sequence
ON SCREEN DISPLAY---> (DIGIT 5) ---> (VOLUME +) --->STANDBY
Method of Cancellation from Service Mode
1. Set the standby mode (Press “ (TV STANDBY)” button
on the commander), then press “ (TV STANDBY)” button
again, hereupon it becomes TV mode.
Thanks
Oct 29, 2008 | Sony KP-53HS30 53" Rear Projection...
Boston Acoustics TVee Model 30 Soundbar with Wireless Subwoofer Logo
149 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
