Question about Mitsubishi WD62527 62 in. LCD HDTV
Wont come on
I turn on tv green light blinks then blue screen comes on then tv goes off
    Top Expert:
  • Mitsubishi Master
  • 74,211 Answers
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 21, 2013
lovejoy91
  • 691 Answers
SOURCE: the tv wont turn on
Sounds like DM board has bad capacitors, depending on Model, maybe FMT board
Posted on Mar 10, 2011
jeramie_curt
  • 36 Answers
SOURCE: flashing green light and then blue welcome screen
Possible bad lamp, color wheel or both. Do you also hear a grinding or louder than normal whirling sound? If so, then it's your color wheel. If not, try just replacing the lamp.
Posted on Feb 02, 2012
gopakumarg43
  • 74211 Answers
SOURCE: flashing power light
Fault with serial data; serial clock signal path. Serial clock path is OK, but data path must be traced. Seek tech support. This is a very skilled work.
Posted on Jun 05, 2012
bugoy31
  • 1238 Answers
SOURCE: my mitsubishi 60 inch tv
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 14, 2012
SD Tech
  • 14553 Answers
SOURCE: WD-65737 green light blinks but tv wont turn on
The green blinking light of death this is called, it is the digital portion of the set trying to boot up, only one simple thing to try here, get at the front keyboard where the Tiny reset button is and unplug that board, I can tell you how if needed.
The light should if power was removed and returned blink for about 70 seconds and go out--then set can be turned on.
The common circuit problem that (other than a bad reset button) is 4 filter caps on the main power board that puff up---follow power cord to that board and look for:
The reset button is easier to look at and disconnect, the caps are usually easy to see if puffed up--if I remember this model there are 4 1000uf(microfarad) at 16 volt rated caps that go bad, if even one is puffed replace all four--kits do exist or you can buy the caps by themselves. The kits are not real expensive and may come with the pico fuse that is in that power supply.
Posted on Dec 14, 2012
Wd-73737 wont turn on blinking green light
First is if you are able to get it to turn on and blue screen only appears it will shut down as no signal noted.
If you can get it on with Mitsubishi remote : Menu, 1,2,3 enter
This is the soft reset and the set also has a hard reset.
Try the soft reset first and let me know what happens.
Mar 09, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
POWERING ON
good day
since it is unusual, have it checked by a competent technician. it may only be a simple reset but nevertheless at least you wont be bothered again by that problem
Oct 09, 2008 | Sylvania LC260SS8 26 in. LCD Television
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
I have an Emerson TV 32
i turned on my tv and it blinks green continuesly. it wont turn off to red light. i unpluged it for 30 min. repluged it and green light comes on and wont stop blinking
Sep 07, 2008 | Emerson EWL3706 37 in. LCD Television
Mitsubishi WD62527 62 in. LCD HDTV Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
