Dryers Logo
Posted on May 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Glow coil glows but does not ignite
Glow coil glows but doesnot ignite
Anonymous
Level 3:
  • Master 999 Answers
  • Posted on Jun 09, 2009
Anonymous
Master
Level 3:
Answers
999
Questions
Helped
310992
Points
2740
Without an amp meter to measure the drop on the coil I use a long screwdriver and tap the handle end on the valve coils while the ignitor is glowing. IF the burner lights the problem is the ignitor. Either way its either a coil or the ignitor.
Eric
Dryer runs but will not heat. Igniter glows bright red, gas doesn't ignite. Igniter stops glowing after about 10 seconds, dryer keeps running. Timer works, buzzer works. .
Hello. You might have defective valve coils not allowing the gas valve to open. Check to see if you have 120v at the coils. The valve assembly is nothing more than an electromagnet. When the coils are energized, they make a spring-loaded plunger withdraw, allowing gas to pass. After the current is shut off, the springs force the plunger to close off again--just like the coil of wire around a nail(battery powered when you were a kid) and you could pick up small objects magnetically. HOWEVER, you also say that the ignitor glows "bright red"--how old is the dryer? The ignitor usually glows a VERY bright orange--so brightly that you almost can't look at it! A classic symptom of a worn out ignitor is that the center glows but the rest of the glow bar doesn't. If you have an ammeter(meter that checks amperage(current), you should measure about 4 amps +/- on one of the wires going to the glow bar. There is also a flame sensor that will allow the valve to open when it senses a bright enough glow from the glow bar. If you are unsure how to check any of these devices, PLEASE call for a svc tech. I hope I gave you some insight and helped you! And yes, I'm an appliance tech.
Aug 21, 2015 • Dryers
1helpful
There is no heat on any of the cycles.
Check Igniter, Igniter Sensor (Senses Igniter is glowing) & gas valve Coils. Remove Front or rear access panel to observe/access these items. Set heated dry cycle & start dryer while observing Igniter, should start to glow bright orange for several seconds, sensor should send millivolt power to valve coils that will CLICK opening valve producing blue flame for heat. If Igniter doesn't glow within a minute, its bad, If it glows & nothing else happens it's either Sensor or Coils are bad, check the coils by using Ohm meter across plug ends of coils, if bad you will get no reading on meter, coil is open & no good, or take both Sensor & Coils to repair shop and have them tested. All 3 are accessable thru access panel opening.
Feb 14, 2011 • Dryers
The dryer has no heat when turned on.
Check your coils & igniter. Access door usually located in lower right front of dryer. Remove (pry up & out from bottom of panel, if no screws, exposing burner assembly. Set dryer for heated dry and start, you should see the igniter glow bright orange (give it at least a minute) followed by a CLICK sound,(again, a few seconds) this is the coils opening the gas valve, followed by a blue flame for heat. If no glow, replace igniter. If igniter glows bright and no click, replace the coils.
Feb 13, 2011 • Dryers
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 • Dryers
Igniter glows but gas does not ignite
If the ignitor glows that means everything in the assembly is working and has continuity, so why doe the gas not light? Solution:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 12, 2010 • Dryers
Not getting hot. vent line is free of lint. Maytag Atlantis/gas
Chances are the hot surface glow igniter is not working. Most likely it is burned out. Set the controls to dry in high heat and note if the glowing coil does in fact glow. If not, it needs to be replaced. Open the burner access door and then turn the dryer on. Watch inside the burner compartment for the glow coil to light up and glow. If all the controls are set correctly on the front control panel and the dryer is running, but the glow coil fails to glow, you've located the defective part. The glow coil will need to be replaced.
To remove the coil, turn off the gas first. Unplug the dryer from the electrical wall plug. Then remove the entire gas valve as an assembly. The nut on the gas valve to remove it from the gas supply pipe turns counter clockwise. There will be small sheet metal screws used to secure the plate to which the burner assembly parts are attached. The plate holds the entire assembly and is attached to the bottom of the dryer's cabinet.
Next, remove the glow coil from the burner assembly. Take the entire assembled part to the local appliance retail parts store for a replacement coil. Glow igniters are fragile and they break easily. Handle and install the new igniter carefully. Glow igniters are a non-returnable and non-refundable electric component.
Be advised that some new replacement igniters do not come with quick disconnect ends. In this case, it is OK to cut off the quick, disconnect from the old igniter and attach it to the new igniter. Simply clip off the wires several inches above, disconnect the old igniter, attach to the wires of the new igniter, and wire nut the two ends together. Repeat the process to attach the other set of wires and wire nut them together. There is no positive nor negative polarity to be concerned with.
Additional Suggestions: Read the manufacturer's online Web site for product information, problem possibilities, causes and solving methods, part locations, disassembly, reassembly methods, repair procedures, instructions, pictorials and schematics, which may be available online.
1helpful
Gas dryer does not heat GAS DRYER DOES NOT DRY CLOTHES WITH HEAT
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
Bake burner flutters
[ the glow coil } the ignitor is call needs replacing it'snot getting hot enugh to open the safety valve.it's no more then $45.00. Berry common problem.
Top Dryers Experts
john h
