Question about Technics Audio Players & Recorders
My digital cd turntable stuck in reverse mode
Will only spin in reverse even when its on forward
  • 2,113 Answers
The insides of turntables are relatively simple. Open it up. Remove the turntable. Look for any flexible sheet metal fingers that touch other contacts to make decisions. One of them will be not releasing or have a piece of plastic etc holding it from moving. If not then look for the switch that does the reversing etc. Switches may not be able to be replaced so see if you can take it apart and rebuild it. If not then you may have to butcher the turntable by drilling and installing your own switch.
Posted on Nov 21, 2013
Vs auto have forward gears even in reverse any ideas please
A4LD stuck in forward, even while in neutral and reverse. - Ford ...
https://www.explorerforum.com/forums/showthread.php?t=216567
May 27, 2008 - 19 posts - ‎5 authors
I did find a thread that referred to an "always in a forward gear" A4LD problem, ... Eventhough band adjustment should not have anything to do with the .... in the transmission and then it auto shifts through the gears normally.
700r4 forward in all gears, even neutral, no reverse - Third ...
www.thirdgen.org/forums/.../631383-700r4-forward-all-gears.html
Oct 21, 2011 - 700r4 forward in all gears, even neutral, no reverse ... It has no reversebut when I put it in reverse it tries to pull the motor down like the rearend ...
my car is not moving forward or backwards even with gea
Dec 27, 2015 | Cars & Trucks
My shredder says it will shred cd's and dvd's but when I tried, a cd went in 1/2 way and now is stuck. Motor runs but nothing happens in forward or reverse
You can turn the shredder over (after unplugging the power cord) and see if you can pull the pieces out from under side.
Sometimes the motor gear teeth break off, and the motor just spins but wont go forward or reverse.
Hope this helps.
Feb 25, 2015 | Shredder Office Equipment & Supplies
Singer 4166 suddenly started sewing only in reverse even when forward mode checked
open the top of the sewing machine. Then press the button or lever that changes the forward reverse mode. You may find that something got stuck there where it should effect the machine part. May a drop of oil on that spot can help?
Jan 11, 2014 | Singer 4166 Sewing Machine
It's not spinning
sometimes the forward/ reverse switch gets stuck 'inbetween' make sure it is fully in forward or reverse. you did not attempt to operate it in the video, is it air or electric?
Mar 07, 2013 | Tools & Hardware - Others
CD BACKSPIN
CD Mode does not react in the same manner as as Vinyl mode when you try to back spin. At the very least, you will only be able to go back a few bars. It's mainly used to set the Cue properly.
If you want it to back spin, you'll have to use the Vinyl mode.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 03, 2009 | Pioneer CDJ-800 Turntable
My turntable has stopped spinning when i press start. when i stop it it spins back for a sec then nothing.when i take the plate off the turntable the bit that would spin seams like it can't move free is...
Since it's Direct Drive there's no belt to fall off. There is an electronic brake.
Could your problem have something to do with the Reverse function? Check the L.E.D. Perhaps cycling it will help.
USING THE REVERSE BUTTON:
1. Press the REVERSE (17) button to reverse the rotation of the
PLATTER (2) (the REVERSE LED (17A) will light while in reverse
mode). Press the REVERSE BUTTON a second time to return to
normal play.
http://www.geminidj.com/disc._prod_manuals/TURNTABLES/PT-2100/PT-2100.pdf
Mar 07, 2009 | Gemini PT-2100 Turntable
CDJ800MK2 problems
Code E-8380 is a read error. Either the CD tray itself is stucked/jammed, or the Play switch is not sending the correct signal to the CD amp.
In either case, professional assistance is required.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Sep 09, 2008 | Pioneer CDJ-800 Turntable
Platter spins very slowly
Well hope fully its something small. check your pitch control first make sure its not set at a slow speed. then check your start stop knobs at the bottom of the table. roll them one way then start it see if that works, then the other way... if its not that then its possibly its a malfunction ,, Numark with there new awesome products but sometimes faulty that turntable wigs out goin slow then normal then slow ect... If its less then a year send it in it is coverd by warrantee
Oct 07, 2007 | Numark CDX Turntable
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
