Question about Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount
Craftsman 32" 10 hp snow thrower
How does the fuel line route from the gas tank to the carb..
    Sergeant:
  • Craftsman Expert
  • 417 Answers
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Posted on Nov 22, 2013
4 Suggested Answers
  • 6468 Answers
SOURCE: craftsman 18" chainsaw runs but dies when I press the throttle, new carb and fuel lines low and high speed set at 1 turn .
remove the muffler and run it after seeing that it runs good open the muffler and clean the screen inside
Posted on Sep 29, 2012
  • 4088 Answers
SOURCE: craftmans snow thrower model 247.887900
Remove the fuel line from the carburetor to check the fuel flow from it--there should be a thin stream of fuel flowing out--if it just drips, something is plugging the line, fuel filter, or shutoff valve. If it seems ok, then the float and needle valve in the carburetor bowl may not be allowing fuel to flow into the carburetor. It is probably necessary to remove the carburetor to check these components. Make sure to have fresh fuel in the tank. Hope this helps!
Posted on Jan 23, 2011
  • 6468 Answers
SOURCE: older craftsman (poulan) chain saw,,, no fuel sucking to carb
is there a check valve on the line for the return?
Posted on Sep 08, 2012
I need a service manual for snow thrower model# 247.888160
manual can be had at link below, if carb. is leaking fuel chances are it has dirt in it and requires rebuilding which I will post a second link to.
press the helpful button
Craftsman 247 888160 Owner Manual
How to Fix Snow Blower Carburetor
Oct 15, 2015 | Craftsman Sears Snow Thrower Manual Model...
Can't find the fuel line in my mtd series 300 snow thrower
that line has to be right there either on the bottom or side of that tank ,take the cover off and see where the fuel is coming from alot of times it is the bowl on the carburator that leaks this should be drained at the end of use so it does not get a clogged needle and seat at the end of the season , this is the number problem with things that are used only a few times a year and they let them sit with the fuel in the carbs ,
Feb 22, 2014 | Mtd 2-stage Snow Thrower Wheel Drive Belt
Carberater for my snow thrower isn't getting gas
The carburetor could be clogged. Try spraying some carb cleaner into the engine to see if it starts. If it does, then some part of the carb may have varnish clogging some of the ports.
Jan 30, 2014 | Craftsman 24" 208cc Dual-Stage Snow...
Craftsman snowblower
does it have a fuel shut off valve on it , make sure the tank hose to carb is clear ,take the carb bowl off to see if the float and needle and seat are not sticking
Jan 22, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Will not start even withew gas
Try a spray of starting fluid into the carb. If it fires you know you have good spark. If it did not fire replace your spark plug. If it still won't fire point and condensor need to be replaced. If it did fire spray the starting fluid in the carb a few more times to pull the old fuel through the fuel line til the new gas gets through the carb and then it should run. Some machines have a fuel shut off valve make sure it is open.
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Carb adjustment and what is the correct spark plug
If the snow thrower worked last year I would suspect old fuel in the tank. Dump out the old fuel in the tank and put in fresh. Put a squirt of starting fluid in the carb and try to start it. If it fires the ignition is good. Do this a few times to pull the old fuel through the carb and fuel line. When the new fuel gets through the fuel system to the engine it will stay running. The spark plug in the engine will have number on it. Get one with the same number if you want to replace it.
Dec 10, 2013 | Craftsman Sears Snow Thrower Manual Model...
Engine on 30"Craftsman 2009 snow thrower won't prime. Primer button and connecting tube look good. Primer button won't send gas to the carb.
the priming bubble can look totally perfect, but all it takes is a pin hole and right around the retaining ring is hard to spot a crack and you should also check fuel lines in tank
Jan 07, 2013 | managemylife.com
Craftsman Arnold Mtd Snow Thrower Blower Light Easy Mount Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
