Question about Cameras
Solution digit placing puzzle
Write the numbers 1 through 8 in the circles so that no two numbers inside circles joined by a line differ by 1
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Inside which circles?
Posted on Nov 21, 2013
2 Suggested Answers
MarkDay
  • 111 Answers
SOURCE: Prints have darker same color circles are the same size.
The ccd sensor is dirty. Have it cleaned at a camera shop. You can do yourself with sensor swabs and eclipse fluid but it a is very delicate operation. Local shop here cleaning is $45 and no spots, well worth it.
Posted on May 15, 2008
Is there a way to solve the 13 piece puzzle ?? a starting point would be helpful
when doing picture puzzles ( jigsaws) the best place to start is the edge pieces ( those pieces with straight sides
corners will have 2 straight edges joined and the rest will be one side straight
then go for same colours or lines
Jun 24, 2015 | Puzzle Toys
95 montero,3.0l,need a diagram of firing order.HELP!
FIRING ORDER IS 1 2 3 4 5 6 STANDING IN FRONT VECHICLE CYLINDERS TO THE LEFT SIDE ENGINE FACING YOU ARE 1 3 5 CYLINDERS ON THE RIGHT SIDE FACING YOU IS 2 4 6. NOW DRAW A LARGE CIRCLE TOP OF CIRCLE WRITE NUMBER 1 BOTTOM OF CIRCLE WRITE NUMBER 4 ON LEFT SIDE CIRCLE UNDER NUMBER1 WRITE NUMBERS IS 2 AND 3 ON THE RIGHT SIDE CIRCLE BELOW NUMBER 1 WRITE NUMBER 6 AND 5 THAT CIRCLE YOU DREW IS YOUR DISTRIBUTOR PLUGS LOCATION NOW YOU CAN PLACE PLUGS WIRES FROM DISTRIBUTOR TO THE RIGHT SPARK PLUGS LOCATION TO THE CYLINDER BLOCK.LET ME KNOW HOW IT WORKS OUT.
Oct 26, 2010 | Mitsubishi Montero Cars & Trucks
SEVEN SQUARES ON A PIN BOARD I CANT GET IT
Hi there,here is you answer,enjoy
There are 6 lines of pins
On each line they are in different positions
So for this occasion we are gonna number these from 1-28,from left to right then from top to bottom
We will give each square a colour and a number
1*Large blue square join the 4 corners at pins 8 to 16 to 23 to 28
2*Large yellow square join at pins 4 to 12 to 21 to 27
3*Small red square join at pins 17 to 22 to 24 to 26
4*Small brown square join at pins 14 to 18 to 20 to 25
5*Small light blue square join at pins 5 to 9 to 11 to 15
6*Small white square join at pins 1 to 2 to 6 to 7
7*Medium white square join at pins 3 to 10 to 13 to 18
Hope this helps its the easiest way i think i can describe it
JonnieC
Jan 06, 2010 | Nintendo Professor Layton & the Curious...
I can't seperate the pigs
There are 17 PINS. Count from 1 -- 17 left from right on each line.
Take care when counting the Pins. Make sure the ropes surround the middle Pig
Rope 1) Join Pin l -- to Pin 16
Rope 2) Join Pin 3 -- to Pin 14 (Pin 14 is the Pin nearest to the bottom Pig's nose)
Rope 3) Join Pin 4 -- to Pin 5
GOOD LUCK
Apr 27, 2009 | Nintendo Professor Layton & the Curious...
I need help with puzzle 100
There are 28 PINS -- Count each PIN starting from left to right on each line. (1 -- 28)
Square ( 1) Join together Pin No's ( 1 -- 2 -- 6 -- 7 )
Square ( 2) Join together Pin No's ( 4 -- 12 -- 21 -- 27 )
Square ( 3) Join " " " ( 5 -- 9 -- 11 -- 15 )
Square ( 4) " " " " ( 3 -- 10 -- 13 -- 19 )
Square ( 5) " " " " ( 8 -- 16 -- 23 -- 28 )
Square ( 6) " " " " (14 -- 18-- 20 -- 25 )
Square ( 7) " " " " (17 -- 22 - 24 -- 26 )
GOOD LUCK.........
Apr 12, 2009 | Nintendo Professor Layton & the Curious...
How to solve no 100: seven squares
There are 28 PINS. Count each PIN starting from left to right on each line. (1 to 28 )
Square 1-- Join together PIN No's ( 1 -- 2 -- 6 -- 7 )
Square 2 -- Join " " " " ( 4 -- 12 -- 21 -- 27 )
Square 3 -- Join " " " " ( 5 -- 9 -- 11 -- 15 )
Square 4 -- Join " " " " (3 -- 10 -- 13 -- 19 )
Square 5 -- Join " " " " (8 -- 16 -- 23 -- 28 )
Square 6 -- Join " " " " (14 --18 - 20 -- 25 )
Square 7 -- Join " " " " (17 -- 22 - 24 - 26 )
Hope you can complete this Puzzle now ----------- GOOD LUCK
Apr 01, 2009 | Nintendo Professor Layton & the Curious...
Seven boxes puzzle
1 2 3 4 5 6
. . . . . . 1
. . . . . . 2
. . . . . . 3
. . . . . . 4
. . . . . . 5
. . . . . . 6
first box is the 4 corner dots at top on left hand side
Biggest box is 4th across on first line 1st across on 3rd line 3rd across on last line and 3r up on last line on
next box bottom left hand 2nd across 3up, 1st 2up, 3rd across 2up, bottom line 2nd frm left.
next box is just about inside biggest box, slightly smaller
next box is also inside biggest box again smaller
th other 2 boxes are the same size of the one in the left bottom corner, 1 inside biggest box and then you should find the last on no bother.
Hope this helps
Feb 11, 2009 | Nintendo Professor Layton & the Curious...
May 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
